Old 10-16-2011, 05:30 PM
Whtshos's Avatar
Whtshos Whtshos is offline
Bolt and stud source??
New to my son. First off is a water pump and floor replacement. I have found that is is a giant pleasure to remove items off of an engine that is all original and never been touched . It appears all items are original and only have 33 years of natures Rust-tite on all fasteners. Only broke 3 bolt during waterpump removal. To finish removing broken studs, the timing chain cover had to be removed.....JOY JOY JOY as ya'll know when the bolts have oxidized themselves to the aluminum housing.
T
The stud/bolt that secure the timing cover and provide an anchor point for the PS bracket (under the box end)is one of the frozen studs that broke. Who has been the trusted supplier for such automotive bolts??
I need to replace all of them as some are stretched and others are a bit slim thru the shank. What is the description of the dual threaded stud/bolt?
Its only money............
82" J10 Honcho
_____l_,\____\,__
l_(--)-l__l---0llllllll0
_(o)_)__(o)_)--o-)_)_
79" Chief W/T 'TANK'
//___/l_,\____\,__
l_-----l__l---0llllllll0
Old 10-22-2011, 07:48 PM
Whtshos's Avatar
No one?
82" J10 Honcho
_____l_,\____\,__
//___/l_,\____\,__
Old 10-22-2011, 08:11 PM
jeepfan93's Avatar
jeepfan93 jeepfan93 is offline
I don't have any spare motors or studs around, but get the broken pieces out and the hardware store can hook you up
Jeeps are Jeeps, keep Jeepin
>It's not about the ten hour drive to get the rust bucket jeep, it's about where your your going when it's done
87GW 99 Durango 5.2 drivetrain, SOA 35in Falken Wildpeak. MT rims
1997 Ram 1500 5.2 33in Falken Rocky Mounts for haulin
Old 10-22-2011, 10:33 PM
Rich88's Avatar
Rich88 Rich88 is offline
That is a special purpose bolt, and I've never seen one at large. I'd get a threaded rod and two nuts & some washers. Cut the rod to length to match the original. When reassembling, screw the rod in as tight as you can, then put a washer & nut on and tighten up against the water pump. You'll have extra length of rod still sticking out past the first bolt for the PS pump bracket to fasten to with another bolt & washer.
Old 10-22-2011, 10:52 PM
cedmonds cedmonds is offline
I get all my funky hardware from mcmaster car. Lord help you find it in their massive inventory of hardware
Old 10-23-2011, 12:46 AM
Max Hunter's Avatar
Max Hunter Max Hunter is offline
A machine shop that takes walk in jobs should be able to help you out if you need a specialty fastener made.
Old 10-23-2011, 12:55 AM
Brown Bear's Avatar
Brown Bear Brown Bear is offline
I'd source it through a local screw/fastener joint, they'll have the knowledge and you won't have to go wading through all the inventory yourself.
NathanielButts
IFSJA Member #18
RIP-USS Minnow-The three hour tour is over.
MacGuyver - 1985 Grand Wagoneer
TFI, Edel Intake, Holley 80457S (yeah, it's shiney), K8600, K&N, Taylor Wires, Ford HD springs, and way freakin' cooooooool
Old 10-23-2011, 07:57 AM
Whtshos's Avatar
Thats why I was hoping for a known description
Thank you everybody, wasn't sure if there was a hidden sponsor that had an accessory bolt KIT per say. I've got an e-mail into ARP checking on such a mythical monster for the AMC. If I get good news, I will pass it on.
Again, thank you!!
82" J10 Honcho
_____l_,\____\,__
//___/l_,\____\,__
Old 11-30-2011, 08:24 PM
danielheren danielheren is offline
Here in Portland we have a Parkrose hardware store that has more types of fastners than I've ever seen in one location. Stuff I can't even find on the internet. I know I've seen studs with different threads on each end there. Let me know if you have something you really can't find and I'll give em a look the next time I go.
74' J20
Old 12-01-2011, 12:02 PM
chrisnsarah's Avatar
You can always source another one at a wrecking yard. That stud is pretty common with AMC V8's. If all else fails, cobble one up or have a machine shop make one.
A trick someone told me to combat the aluminum oxidation is paint the bolt part that sleeves through the aluminum cover and use anti-seize on bolts that thread into aluminum.
'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
Old 12-01-2011, 12:48 PM
Tripwire's Avatar
Tripwire Tripwire is offline
if you had a pic that would be helpful, i have a box full of bolts left over from part outs
trip
Abort? Retry? Ignore? >
Old 12-01-2011, 01:13 PM
codyyy codyyy is offline
Not sure if they have a Fastenal there, but you might try that. They sell in bulk though I believe. Otherwise, Dorman should make an exhaust stud that would work as well. Find an auto parts store that still has the orange Dorman bins, or someone knowledgeable enough to know what you need, but you'll need the dimensions first. Looks to me like a 5/16-24 stud. Something like this may work. Only problem being the gap in the middle. Otherwise, like what was mentioned Allthread will work.
http://www.dormanproducts.com/p-32232-29202.aspx
Looking for one
Old 12-02-2011, 02:55 PM
Whtshos's Avatar
Thanx for the ideas. I tried some hole-in-the-wall joints and found 2 that I needed. Went to a Jeep wrecking yard and every canidated had the engine removed. Threw the hood on the last one, no engine . BUT... all the front bolts were lying in the old air cleaner . Like they knew I was coming. Was hoping for new bolts but I've learned not to be too pickey.
82" J10 Honcho
_____l_,\____\,__
//___/l_,\____\,__
Old 12-02-2011, 11:51 PM
sld's Avatar
sld sld is offline
wrong thread and wouldn't let me delete.
1981 WT Cherokee Chief /360/TF727/208/ Holley 600CFM/ Performer Intake/ Edelbrock headers/ Skip White HEI, switched dizzy gear. Patriot Side Pipes.
Stripped aluminum carb stud hole djongeward General FSJ Tech 17 08-16-2011 03:50 PM
Hood Connection Bolt Issue...Any Ideas? brtisch General FSJ Tech 4 04-21-2009 09:29 AM
Power steering adjustment stud Mack_T General FSJ Tech 5 07-09-2007 08:10 AM
14 bolt lug stud ???'s Brad W. Off-Road FSJ Tech 8 07-31-2006 08:57 AM
Stud mount VS. bridge mount rockers. Help JeepsAndGuns General FSJ Tech 6 09-09-2004 11:29 AM
