Late last night I had the misfortune to have
my waterpump shell -- a great big vibration -- which went away -- and about 5mins later a vast amount of steam...
With a little help and several gallons of water, I limped home.
This AM I tore things down, and not only is the pump foobar -- the alternator bracket is cracked all to hell -- and has an old weld that seems to say this has been going on for quite a while.
I can't find a pump here is Austin, and seriously doubt that the alternator bracket will be easy either.
Any suggestions on the bracket ? I think I can get the pump from NapaOnline.
Here are some pics of the pump and bracket -- I am back outside to try and flush the bearing bits out of the block...
Thanks, Mark
1972 wagoneer -- 360,
the monkeywagon in disrepair
the evil pump -- and whats left of it
a mostly cracked bracket
Thanks, Mark
