Greetings from East Tennessee!
  • Theodore
    • Sep 10, 2018
    • 253
    Am in Kingsport. New to the Wagoneer scene - got this for my wife - has wanted one for years - she calls him Teddy; I can’t bring myself to, so we’ll say Theodore.
    Is a ‘90 model. Tripped across it locally on Craigslist back in August.
    While the clearcoat is basically gone, the body has no rust at all - with nice patina. At this point, we’re working on mechanical reliability issues. First thing was idle, and tuning - has the Affordable Fuel Injection set up on it & would run after the key was off.
    Next was weather-proofing - all the doors leaked - replaced/repaired the weather barriers & replaced the window wipes.
    Then on to replacing the pinion bearing in the rearend & repairing a massive transmission pan leak. Fortunately, we’ve found a great mechanic here to help with things I’m not equipped to do.
    Am looking to do as much as i can myself & learning along the way, while farming out the rest.
    Have a few other things on the list that need attention, but no hurry. Otherwise, everything else works:
    - Auto lock-you-out feature; bought replacement door lock springs from B.J.’s, but wire gauge was too heavy; would lock, but not unlock - the springs were binding. Anyone know where else to get these?
    - Headliner replacement - it’s out now, along with overhead console
    - stock height leaf springs & shocks, if needed
    - Whitewall tires
    - Body bushings
    - Upholstery repairs or finding seats in better condition
    Thanks to all whose posts have gotten us this far. Will likely be leaning on the community as we get deeper in.
    Edit: noticed the post was chopped off mid-way of the first sentence. Not sure what happened.
  • SOLSAKS
    • Jul 25, 2016
    • 1781
    welcome to the forum
    dave in NC
    • Theodore
      • Sep 10, 2018
      • 253
      Edited the original post. Noticed the post got chopped off mid-way of the first sentence. Not sure what happened. The preview looked ok.
      • medinajim2000
        • Oct 28, 2005
        • 818
        Welcome from Knoxville. My second one was a gold 89.
        https://www.facebook.com/ClassicGrandWagoneers/
        87 GW (White) - Incoming
        89 GW (Black Cherry) - In Resto
        85 GW (Gold) - In Resto
        86 GW (Garnet) - In Resto
        84 GW (Bronze) - In Resto
        89 GW (Gray) - (Gone)
        89 GW (Gray)(Gone)
        87 GW (White)(Gone)
        86 GW (Blue)(Gone)
        88 GW (Gray)(Gone)
        89 GW (Gold)(Gone)
        89 GW (Gray)(Gone)
        75 Cherokee S (Blue)(Gone)
        • SOLSAKS
          • Jul 25, 2016
          • 1781
          on the door lock situation
          on my driver door i had the same "phantom lock out" issue,....
          i went to the hardware store with the
          door lock knob portion that you screw off
          tested black rubber grometts
          got the one that allows the lock knob to slide thru with a little resistance
          and at the same time fit the hole in the woodgrain portion of door panel
          i have not been locked out since. although hiding a magnetic key case
          somewhere along the underbody is not a bad idea.
          good luck
          dave in NC
          • ProTouring442
            • Mar 15, 2011
            • 702
            Welcome from Harriman, TN!
            Good looking rig.
            You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
            • rang-a-stang
              • Oct 31, 2016
              • 5512
              Glad you're here! Looking forward to seeing lots more as you gettim going!
              Chuck McTruck 71 J4000
              (Chuck McTruck Build Thread)
              00 Baby Cherokee
              • Theodore
                • Sep 10, 2018
                • 253
                good luck
                dave in NC
                That's a great idea - thanks!
