Hey guys.
I have a bit of a looping idle issue.
I assumed that it was a vacuum issue, but as it's a 72 with basically no lines I am not sure where it would come from.
I have checked the manifold, the carb mounting and the advance. All seem fine.
It loops under 900 RPMs by 50-100 RPMs.
The only other thing I have noticed is that it feels a little as though it's starving out at high RPMs when I give it the beans. If I back off on the gas though it does OK up in the high RPM range.
I dont recall that it did this before I have the electrical system replaced.
I checked the timing today and I set it at 10 BTDC with the vacuum advance off and plugged.
Any ideas on where to start?
