When flexing now, your pinion gets pointed towards your transfercase. When flexing with a shackle reversal, your pinion gets pointed towards the ground.
You will need to make sure that your drivelines can handle the extra angle.
You can rotate the leaf perches around the axle a little bit, but that is a lot of work for anyone who is already spring over. Plus, I wouldnt reccomend cheating it more than 2 degrees anyway otherwise it will wander like a yaht at higher speeds.
