Old 04-03-2011, 03:28 PM
Tripwire's Avatar
Tripwire Tripwire is offline
boy bodywork puts a bee up my mini-skirt...
WoW !!!
I have always done half hearted bondo and primer jobs with a rattle can...but this time is my first attempt (practice) on a tailgate the way the pros do it
sand with 120, apply 2 coats of primer - let sit overnight, use "guidecoat" to find all the low spots - sand with 120 again...primer again....and again and again - yes i used some "glaze" to fill the really low spots, got it smooth as a babys butt at 320 grit with no low spots or scratches - what an ordeal
plus ya have to keep cleaning the @#$%^& gun all the time
took me an entire weekend to get to the point where i can lay down a test basecoat on a perfectly flat panel yes its my first time and hope with experience to do a panel alot quicker, took me quite a bit of primer and sandpaper to get the hang of it
glad i have time and lots of beer...no wonder they quoted me 5 K to paint my rig start to finish
Abort? Retry? Ignore? >
Old 04-03-2011, 03:36 PM
badaboom's Avatar
badaboom badaboom is offline
I hear YAH - Cheers
Where are the Pics?
Of the fruits of your beers
1981 Jeep J10 Laredo, 401-V8, 625 Carter, Lunati 262/268, Edelbrock Performer, MSD Ign., Hydroboost, Hyd. Clutch, Flow Cooler WP, Be Cool Aluminum Radiator, Doug Thorley, NV4500 5-Spd, NP-231D, 3.73 F/R Trac-Locs, Rustys 4" Lift, Vintage Red Metallic, Black Interior and 33X10.50X15 BFG, FiTech400 to come - IN PROCESS Bling Bling Cha-Ching
Old 04-03-2011, 04:08 PM
smogdredd's Avatar
smogdredd smogdredd is offline
Been there
I used another form of general anesthetic when I painted My Bronco, came out real nice. Fire engine red with white half cab. Shadowed the Ford on the tailgate and did some cool pinstriping. I needed lots of pizza and and doritos too.
'63 wagoneer '87 360 running gear except T case (207), warn hubs, 3.56 diffs and EFI Holley pro-jection using ford cfi throttle body Stock dist. with four wire HEI module.
'67 Scout 152cid w/EFI and turbo also My own a little help from Chrysler. I am a fabricator, I make stuff up!
facebookGGAutoCare
Old 04-03-2011, 04:22 PM
Asphalt Cowboy Asphalt Cowboy is offline
Yep, it's time consuming and labor intensive.
Wait'll ya get to patch out rust.
1979 Wagoneer
360/TH400/ Q-Trac/D44's
31-10.50's on Truck Rallies
1965 Gladiator (model unknown)
T98, D20
D44 front D53 rear
slightly rusted, heavily neglected
Mouse in the defroster has
been evicted.
I might curse because roses have thorns,
Or I might rejoice because thorns have roses.
Old 04-03-2011, 05:42 PM
Gambler68's Avatar
Rabble Rouser
I put 60+ hours into my LAST rattlecan paint job..50 of that sanding. Not fun.
be careful, mods dont like it when you circumvent the Googly filter..that goes for everyone here..
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 04-03-2011, 06:09 PM
mrtazwrench's Avatar
mrtazwrench mrtazwrench is offline
It about broke the bank, but that's why I paid to have mine done...
Chad
"Let's see that Red Blue Green **** sucker build one of these without duct taping it together!"
88Wag
87J20 Member, FSJ Prissy Restoration Association
83Cherokee WT
82J20
Parts vehicles: 1.5 Wags, 3.5 J20's, 1 J10 1 J300
Old 04-04-2011, 04:54 AM
Originally Posted by Tripwire
WoW !!!
A "pro" will loose money every time they have to spray primer. Primer is expensive and it takes a long time to dry, that's why they only spray it once.
Try perfecting your body filler spreading and sanding technique. Adding some polyester resin (fiberglass resin) to the last coat of body filler (Bondo) will thin it out and allow for a thin coat. 90% of your sanding should be done with 40-80 grit sandpaper.
Resistance is not futile yet.
Old 04-04-2011, 07:43 AM
Crist Clapper's Avatar
I'm being stalked by Steve... Save me!
1990 Grand Wagoneer:
1987 XJ Wagoneer Limited:
Desiree - def: “Much Desired” [orig: French] Desirable Charcoal Gray façade, Wood-grain vêneers,and Tan Leather éssentials"
Member, FSJ Prissy Restoration Association (FJS-PRIS)
Old 04-04-2011, 08:39 AM
1jeep4me's Avatar
1jeep4me 1jeep4me is offline
You wear the mini skirt when you do body work?
Jenny SOLD
1982 Cherokee Chief Wide Track
4 inch lift
360 ci Edelbrock carb and intake
115K
Daisy
1970 Wagoneer by Kaiser
350 Buick/Turbo 400
3.73:1 Limited slip
41K original miles
Lilly
SOLD your a good girl LILLY!
1973 Commando by Jeep
304 2V 3:73 Limited Slip
3 Speed
93K original miles
Old 04-04-2011, 08:46 AM
Tripwire's Avatar
nah some kind MOD editied the title for me - kinda circumvented the googely moogely filter a tad...
but then again if i did paint in a skirt the overspray would help keep my leg hair better control
Old 04-04-2011, 04:18 PM
Chrome's Avatar
Chrome Chrome is offline
Ph.D in Redneckology
..,=====,o00o
//__l_l_,\____\,__
l_---\_l__l---0
lllllll0
_(o)_)__(o)_)--o-)_)___
Old 04-04-2011, 05:34 PM
Tripwire's Avatar
http://i1236.photobucket.com/albums/...1/DSC02663.jpg
Old 04-04-2011, 06:11 PM
badaboom's Avatar
MUM bodyfiller LOL
Old 04-04-2011, 06:14 PM
That's worse than the pictures of my toes I sent you!
Old 04-04-2011, 11:49 PM
Hutcho's Avatar
Hutcho Hutcho is offline
Originally Posted by Crist Clapper
Not to hijack but how do you get the fancy smilies?
Formally known as "oilfieldtrash354"
"Grandpas" 1979 J-10 resto/mod-on hold for now
Preparing for Ouray 2013!!!!
Montreal mechanic and/or bodywork torpedowilliams General FSJ Discussion 2 12-07-2007 10:29 AM
bodywork paint recommendations- inside fenders & wells blakeusa General FSJ Tech 2 10-02-2006 08:35 AM
FSJ bodywork. 1st attempt. UKJeeper General FSJ Tech 21 07-18-2006 04:26 PM
Bodywork patching with JB-Weld??? Bob Barry General FSJ Tech 20 09-26-2004 01:00 AM
BODYWORK...CHECK IT OUT!! OBX-AUTOMOTIVE General FSJ Tech 0 05-07-2002 04:27 AM
