Old 12-03-2010, 05:13 PM
El Jefe's Avatar
El Jefe El Jefe is offline
Homemade beadlock questions
ok, these are the tires I want to get next.
http://www.treadwright.com/shopnow/p...guard-dog.aspx
Ok, see how they are 16.5's? well I had the idea to get me some stock 16.5 rims and make bead locks for them.
My questions are first, is this a stupid idea?
Next, How thick of metal would be best for the beadlocks themselves? was thinking 1/4 mild.
and almost finally, How many holes should they have? 16? 32? I dont wheel hard but would like to get a little more into it.
Thanks in advance.
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
4" lift, 35 inch retreads
Old 12-03-2010, 05:35 PM
j20brett's Avatar
j20brett j20brett is offline
360 AMC
Thanks in advance.
1/4" steel. 32 bolt holes. Call ballistic fab. they do custom orders for not a bad price
Build Thread
Fight Crime...Shoot Back.
ΜΟΛΩΝ ΛΑΒΕ
novacayne75's Avatar
novacayne75 novacayne75 is offline
good tire choice.
sounds like you have a good idea. 1/4 is fine for beadlocks and 32 bolts are the way to go they do seal better. with all the beadlock kits available its not worth trying to cut and drill your own rings. but yea use a set of stockers with a set of weld on beadlocks and you will be set . oh when you install them weld on 4 small tabs to center the tires on the wheels.
78 j-truggy d60/14b,42's,tbi.
97 zj long armed and locked on 35's
03 quad cab 3500 ctd tow pig.
Old 12-03-2010, 05:45 PM
El Jefe's Avatar
well at my work I'm trained on what we call the Little CNC. I can program it and punch all the holes lickity split. And I can get all the metal I need. Then I can just plasma them out.
But, them ballistic fab ones look nice. hmmmm
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
Old 12-03-2010, 08:53 PM
Sambo's Avatar
Sambo Sambo is offline
i have copperhead fab beads and they are fine with 24 bolts i believe.
but if you want a good work out go for the 32 bolt.
btw beadlock wheels are hard to balance if you drive on the street more than the trail!
77 chero DEAD.
Old 12-03-2010, 09:30 PM
Hard Knocks Hard Knocks is offline
Why not just buy a set of H1's and recenter them,with pressed centers?
Old 12-03-2010, 09:48 PM
gtodriver gtodriver is offline
Beadlocks are hard to balance......don't think so. My '65 Pontiac GTO drag race car will do a 1/4 mile in 8.80 seconds at 154 MPH. My rear tires are beadlocked and I have no vibration problems at all....NONE!
Old 12-04-2010, 12:51 AM
travisrda's Avatar
travisrda travisrda is offline
you might want to reconsider the 16.5" and go with some 16" or something more common. I work for one of the largest tire stores in the country and 16.5's arent going to be mad for much longer and as it is there isn't too much of a choice out there.
J Just
E Empty
E Every
P Pocket
1, 77 wagon $200, amc 401 th400 quadratrack 4 in. lift 33-12.50x15
1984 cj-7 Soa w/401, t-18,dana 20 35-12.50x15 1974 j-10 304
Old 12-04-2010, 01:17 AM
78J-10's Avatar
78J-10 78J-10 is offline
check out ruffstuffspecialties.com they make a DYI beadlock kit for a good price. If you want I have a 10 percent discount code for them as well.
78 J-10: 258 w/2100,D20,HD44,14 Bolt,36's (SOLD )
79 J20: 360 T18 D20 33s 36k: current state:
88 Waggy: 360/727/Quad All stock rusty roof 78k :
Tow Rig: 2013 CCLB 4x4 w/ 6.7L Cummins
Old 12-04-2010, 05:21 AM
Sambo's Avatar
yeah dan has good products.i have ordered alot of brackets and etc. from him
77 chero DEAD.
Old 12-04-2010, 03:13 PM
El Jefe's Avatar
I got my disc brake brackets from ruffstuff.
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
Old 12-04-2010, 04:14 PM
El Jefe's Avatar
Is it really a bad idea to do this for a 16.5 rim? I was figuring 16.5's cause I like the re-treads and wanted 37's.
Also, I do drives this on the road. not alot but once in a while. how bad will it ride with them?
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
Old 12-04-2010, 05:21 PM
j20brett's Avatar
360 AMC
MAny offroad tire suppliers still offer 16.5's. Swampers and pit bull tires for sure do in many sizes. There are way too many people running military 12 bolt and 8 bolt wheels for them to not make them.
Build Thread
ΜΟΛΩΝ ΛΑΒΕ
Old 12-04-2010, 05:33 PM
El Jefe's Avatar
ok. Thats good to know.
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
Old 12-04-2010, 09:46 PM
jtr's Avatar
jtr jtr is offline
If you want those tires, don't waste your time with all those bolts, get some 12 bolt H1s. They will be roughly the same weight and DOT approved. It is cheap to put some pressed centers in them too!
Like said above, when you go bigger Interco and Pitbull make tires to fit your wheels.......no worries
Jeep is gone ~~ Ranger cab truck in the works
393W/C6/203-205, HP60, 14B, 12 bolt H1s, 40" Pitbull Rockers, full hydro, 4 link rear
Build = http://www.pirate4x4.com/forum/showthread.php?t=973973
Old 12-05-2010, 06:31 AM
Subic Jeep's Avatar
Subic Jeep Subic Jeep is offline
Talking H1
My set $1092.92 shipped (US destination NC) 37"tires+H1 12bolt + re-centered not painted no rock ring.
http://www.trailworthyfab.com/
recentered 12 bolts with pressed centers, no rock rings powder coated "wet black"
http://www.pirate4x4.com/forum/showthread.php?t=902637
If not H1 wheels, then these beadlocks are the cleanest I have seen!
http://www.longfieldsuperaxles.com/p...BEADLOCKS.html
85.00/wheel
Lars
I am in the five bananas category!
Cherokee 1981 officially 1974 huh local irony
Gen 1 GM-SB 350 V8 TBI - TH400 - Klune V - Twin stick NP205 w. Nippon shifter
Dana 60 w. ARB locker, hydraulic assist + GM 14FF w. Detroit locker.4-link rear on LC80 19mm coils
Rancho 5036 Shocks 14 inch travel. 39.5x15.5x15 TSL
Old 12-05-2010, 03:27 PM
El Jefe's Avatar
I'd like them rims. But the offset stopped me. But its not expensive to re-center them?
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
Old 12-05-2010, 03:59 PM
Alex,
Didn't see it mentioned above but will your CNC at work cut?
I made a jig for our water-jet so I could have quick repeatability.
http://www.facebook.com/album.php?ai...&id=1359562669
(you should be able to see those, if not I'll get them up on PB later today)
I haven't finished welding in all the centers yet (doing some Rockwell patterns also) but once they are cut it's just math and welding.
Old 12-05-2010, 04:33 PM
El Jefe's Avatar
the CNC I can program doesnt cut. Just punch. Thought it would be handy getting all the holes done. We have a CNC that will cut. But i'm not trained on that. and dont think they would let me use that anyway.
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
Old 12-05-2010, 04:50 PM
El Jefe's Avatar
Me and my dad just got a brand new Hypertherm plasma cutter. Was thinking I could make a jig to cut out the circles consistantly.
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
Getrag 360 to 4BT Questions Logs0012 Diesel Swaps 9 02-22-2010 07:24 PM
Before I crank it up, a few GW/360 questions BenE General FSJ Tech 4 02-27-2007 05:00 PM
Newbie off road questions. Need help. westexhunt Off-Road FSJ Tech 9 10-10-2006 10:21 PM
Registered Numbers So Far 2nd Day East Coast FSJ Invasion 50 06-02-2005 01:00 PM
lots of drivetrain swap questions... rockcandy General FSJ Tech 7 09-19-2003 03:02 AM
