Old 11-09-2019, 11:25 AM
Milesgalaviz's Avatar
Milesgalaviz Milesgalaviz is offline
wagoneer wont crank
Hello Guys
I have a 79 wagoneer that wont crank when turning the key. The lights come one but thats it. I recently swapped out the ignition switch, solenoid and ignition control module to see if any of this would fix it but had no luck. Im able to get it to crank from the two connections on the solenoid but thats it.
Any suggestions?
Thank you
Old 11-09-2019, 11:30 AM
I'd get the wiring diagram here: http://oljeep.com/gw/elec/GW_wiring.html and start tracing the wiring to see where the signal's getting lost.
Old 11-09-2019, 02:08 PM
Thank you I'll look into this and see what I can find
Old 11-09-2019, 02:19 PM
Did you install the new ignition switch correctly( pull the plastic pin before install?) and not get it aligned correctly?
Old 11-09-2019, 02:27 PM
check NSS @ base column
also need to realize "new" electrical parts roll of dice these days.
just because it's "new" means little.
new starter solenoids are especially problematic
Old 11-09-2019, 05:17 PM
I'll reinstall it just to be safe
Old 11-09-2019, 05:18 PM
Neutral safety switch?
Where would I find it ? And what would I check?
Sorry not very mechanically inclined
Old 11-09-2019, 07:01 PM
itselliot's Avatar
itselliot itselliot is offline
Inside the cab at the base of the steering column. The switch closes when the gear selector is in Park or Neutral (only). It passes power to the solenoid.
If the PM's are full,...try e mail!
hpschrot@hotmail.com
616 four 03 44 0 five
'78 J-20 401 Q/T not quite stock anymore....Frame off Resto Mod..Super Cab nearing completion. SOMEDAY
"90 GW 360/727/229/3:31s 2" lift (SOLD in 2015)
'78 CJ7 Built from Scratch over a 7 year span.
Old 11-12-2019, 04:30 PM
I installed a new shifter where the center console would be and if im not mistaken the NSS was overidden
Old 11-12-2019, 10:50 PM
jmac197 jmac197 is offline
Does the ignition switch at the base of the steering column need to be adjusted so the rod fully engages the switch? It has about 1/4" adjustment
First wagoneer camping trip. MikeinColorado General FSJ Discussion 22 06-14-2011 11:40 AM
Team Grand Wagoneer manual rear window crank Gpwoody1 General FSJ Discussion 27 03-12-2011 01:44 PM
V-12 in a 1977 Wagoneer! Out of the Bill Harrah Collection after he died. H Callaway General FSJ Discussion 29 03-07-2007 06:17 AM
Restore current `85 Wagoneer, or buy new one?? ORIGSUV General FSJ Discussion 8 02-18-2007 08:45 PM
