Well, I just finished my 406 stroker build and Expletive Deleted!Expletive Deleted!Expletive Deleted!Expletive Deleted! its a powerhouse motor, but now im having an issue with the TBI...
Starts right up when hot or cold, runs great and will break 37's loose in 1st and 2nd gear with 3.73's, idles great too... the issue is when im driving and put in in neutral when coming to a light or sign it will drop to 300ish rpm and sometimes recover, but most of the time it stalls out... turn the key to start and it fires right back up and idles fine...If i leave it in gear as I come to a light and just pop it out of gear when it hits its idle rpm, its fine or jab the gas and its ok too... Sounds like my Idle VE tables are off?
I adjusted my BLM's since they were a bit off from my previous low comp 360 and adjusted my TBI so the IAC counts were 40-41 at idle...
