Hi there. I'm having problems with everything on my instrument cluster working intermittently. Currently only my temperature gauge works.
I pulled the cluster out and cleaned the contacts and everything but I noticed that the pins in the back where you plug the harness into, were all pretty lose. When I pull down on the harness with everything hooked up, some things (fuel gauge, turn signals, etc) will work but will stop again when I let go of the harness.
Is it those pins that are the problem or do you think there is a short...in all of my cluster wires?
