  #41
Old 03-10-2017, 05:54 AM
SC/397's Avatar
SC/397 SC/397 is offline
Any time I put RTV on gaskets I just snug the bolts down and let it set over night. The next day I tightened all of the water pump bolts, timing cover bolts and oil pan bolts.
Oil Pump: I pack the cavity full of petrolium jelly before it put the gears in.
Then I push the gears in and let the petrolium jelly flow around them.
Then I clean off the excess the best I can.
I spray a light coat of copper coat on the gasket before I put the oil pump cover on.
I Bolted the heads on and got a couple coats of paint on it last night. I like to paint them upside down first so that i get paint on the bottom edge of the heads and everywhere else that you can't get to when it is right side up.
Old 03-10-2017, 12:32 PM
did you verify that the dampner and waterpump clear before painting?
Old 03-10-2017, 04:39 PM
SC/397's Avatar
Yea, we are using the GMB water pump. I have never had a problem with those. It is usually the re-pop cast iron ones that have the issue.
Old 03-11-2017, 12:45 AM
cma's Avatar
cma cma is offline
every update very impressiv!
Markus!
Picture story:
Old 03-13-2017, 07:08 AM
SC/397's Avatar
She is ready to prime the oil pump now..
Old 03-13-2017, 09:51 AM
letank's Avatar
letank letank is offline
Any hints on the correct chamfer size for the timing gear
This is 0.07 , the other gear has a .140 chamfer, there was a talk on theamcforum, but no real answer to the better size if any.
As always you are so thoughfull on giving details
Thank you
74 wag, 349Kmiles on original ticker/trany, except for the rust. Will it make it to the next get together without a rebuilt? Status: debugging a few electricals, needs a new tank.
85 Gwag, 224 Kmiles. $250 FSJ test lab since 02, that refuses to give up but still leaks.
Old 03-13-2017, 10:11 AM
SC/397's Avatar
Thank you
I measured the two original stock ones and they measure about a .082"/.085" x 45 degree chamfer. That makes the Hypotenuse about .116"/.120".(What you are showing in the picture) Be sure to correct the oil slot from the cam feed hole and the transfer slot to the distributor gear on that one.
Old 03-14-2017, 06:22 AM
SC/397's Avatar
The vibration damper had a small groove in it from the seal. It may have been ok but, I went ahead and put a repair sleeve on it.
The oil pump is primed and ready to go.
Old 03-14-2017, 06:44 PM
letank's Avatar
Thank you, and thank you for the sleeve ref num, this is good to add to the list of various sleeves.
Fel Pro 16204 or 21-2504 (in case picts evaporate)
Old 03-20-2017, 09:24 AM
SC/397's Avatar
It runs!
Good luck with photobucket - it is giving me fits. Plus, the sound from my cameraphone is not very good. it sounds much nicer in person.
At this point in time (before the video) It has ran for about a hour total with the coolant changed twice and the oil and filter changed once. It has heat cycled at least 6 times. This is the first time I started it at idle. It runs nice. Now change the fuel pump to the new one and change carb and distributor after that. I like to brake them in with known good parts first!
Old 03-20-2017, 04:27 PM
itselliot's Avatar
itselliot itselliot is offline
link to Dropbox
Not sure if you need an account to see this @ dropbox,..but this is the same as above
For sure it can be downloaded without an account.....but once you use drop box....bye bye fotobucket...is what you'll say....
https://www.dropbox.com/s/kdhv9xohf0...%20up.3gp?dl=0
If the PM's are full,...try e mail!
'78 J-20 360 Q/T not quite stock anymore...Now in Rehab
"90 GW 360/727/229/3:31s 2" lift (SOLD in 2015)
'78 CJ7 Built from Scratch over a 7 year span.
Link to my current toys
http://s1116.photobucket.com/albums/k564/itselliott/
Old Yesterday, 12:50 PM
cma's Avatar
cma cma is offline
Thanks Itselliot for the drop box link! Great sound!
Well done Rick!
Markus!
Picture story:
Time to Build - 1969 Wagoneer Arizona EnigmaticEngineer Off-Road FSJ Tech 26 02-13-2010 08:02 AM
AMC 304 V8 Stroker Build - 327 V8 ! Greg Taylor General FSJ Tech 5 02-14-2008 05:55 AM
NEWBIE BUILD UP DARWIN General FSJ Discussion 42 04-24-2007 11:42 PM
Build a waggy with SOA and 37's for $2500 Blake Off-Road FSJ Tech 21 11-14-2006 02:42 PM
