Originally posted by SC/397
I looked up the specs on the 1061 and other alternatives that would work, but chose not to use them for some reason, I forget exactly why. I'll have to check the books when I go back in to work this evening.
I've been using ACDelco PF-24's instead. There is nothing fancy about them, but at least they work properly.
I've run synthetic in all my engines since they were broken in enough to allow it and they all look like they have half the mileage they really do inside. Castrol Syntec 5W50 has 1200 PPm of zinc. Valvoline Premium Blue diesel 5W40 has 1400. It depends on which one is on sale.
All the guys in parts stores will tell you switching from conventional to synthetic on a high mileage engine will cause leaks and other problems. It's just something we have to say to cover ourselves for liability. I've even switched motors back and forth between conventional and synthetic over and over without a single problem. The two products are miscable and fully compatable. One of the myths is the high detergent in synthetic will loosen sludge and plug the oil galleries. Not true. Diesel oil has even more detergent and one never hears horror stories about switching to it.
Do your research before adding magic additives to your engine oil. It's always better to use an oil with everything you need already included in the additive package rather than adding your own bottles to it, because it can cause an inbalance in the chemistry of the oil and cause substances to precipitate out as solids. I stick with Lucas TB Zinc Plus because it's very potent and I know it works. One bottle has more than 2X the ZDDP you really need for regular driving. i believe AMSOIL has their own additive as well, and if it's like everything else AMSOIl sells, it has to be pretty good.
