Old 08-04-2017, 05:38 AM
SC/397's Avatar
SC/397 SC/397 is offline
Rering 360+268H for DBX11
I finally took a 360 apart that looked really good inside. Good enough to throw new rings, bearings, cam at it and go. Basically, other than hot tanking the block and honing it, it didn't need any machining. The timing was right for DMX11 because he was in need of a engine in kind of a hurry. So, a refresh with the 268H Comp Cam. One of my favorites for a 304 or 360.
360268H by Rick Jones, on Flickr
I had to finish this one up before I could get to it though. A 401 with a Cross Ram and dual 600 Holleys. I put the small 280H cam in it and compression is at 9.5:1. All the wrong parts it seems to me to go under a Cross Ram but it is a street car application that just has to look cool. Amazingly enough, it runs like a top and takes all of the carburetion well. It doesn't put out as much power as a Torker with a single 4 barel does but cool it does look.
401xram by Rick Jones, on Flickr
XRamIMG_3128 by Rick Jones, on Flickr
Old 08-04-2017, 09:00 AM
resized that ginormous pic
Old 08-04-2017, 09:05 AM
SC/397's Avatar
Thanks! Not used to the Flickr thing yet.
Old 08-04-2017, 09:59 AM
Dunno what it is, but have always liked the look of that dual 4bbl setup.
Old 08-04-2017, 12:17 PM
rockosocko's Avatar
rockosocko rockosocko is offline
SC/397- Are those "Smithy's" glass packs?
Like their sound!
Another engine building question.
I've got a real low mileage 360 that ran great and smooth, that I"d like to do a 're-fresh' also. BUT.. don't know enough on the sizes of the cam bearings,
that I might be able to use a Cam installation tool mostly used for Chevy's.
I see them cheap on Ebay but they all say for chevy (the rear 'holder' of the bearing as it goes in the journal)
I also have a couple Caddy motors that I need to build too.
Might YOU know if these can use the same?
Thanks. Errol
Old 08-04-2017, 05:49 PM
SC/397's Avatar
I have no idea what kind of mufflers those are besides.. chrome ones. LOL! My uncle got them at a garage sale and I took them.
If it is like everything else when you compare a sbc to a AMC engine (nuts bolts etc.) everything is smaller on the chevy so I assume that the cam bearings are too. I had a cam bearing tool machine up for me years ago. These are the dimensions of my cam bearing tool.
1.358"
1.386"
1.413"
1.445"
1.480"
I use a pilot at the first cam bearing journal. The diameter of that insert is 1.586"
Old 08-04-2017, 11:09 PM
DBX11's Avatar
DBX11 DBX11 is offline
Its gonna be so nice to have an engine that runs like its supposed to, Rick thanks again for giving a darn about these old engines like you do! If I had gone ahead with the build myself It would have been a mess in my garage for months, and without a stand to break it in on would have been some kinda misery.
Old 08-07-2017, 06:02 AM
SC/397's Avatar
Well your old engine couldn't have ran like it is suppose to. in fact, I can't believe it ran at all!
Scuffedpiston by Rick Jones, on Flickr
Tchain by Rick Jones, on Flickr
Lifter2 (2) by Rick Jones, on Flickr
Lifter1 (2) by Rick Jones, on Flickr
This will be a nice engine for you. I want to keep it for myself..
360268H1 by Rick Jones, on Flickr
Old 09-15-2017, 07:48 AM
Hey Rick, if you get a chance can you reply to my post on the 343 pistom thread. Thanks
Old 10-17-2017, 10:57 PM
DBX11's Avatar
It's installed
It runs, it moves and it stops again! Gotta button up a few last things like the fenders and a small trans pan leak but basically 20 minutes per day for the last 8 months and another old one is back on the road again. Now with new frictions piston seals and a new torque converter for the trans.
While it was apart I found out why it was puking out the dipstick, the vent tube on the top was pushed in too far...also new quadratrac fluid in the transfer, 5 new ujoints in the driveline and the tfi upgrade for the 360 which will also get an msd 6 box after I get everything else rebolted to the inner fenders.
Many thanks to Rick for building the 360 for me and all the details he remembered that I forgot about! Hope to get some work done with this Jeep for years to come.
Old 02-18-2018, 10:43 AM
DBX11's Avatar
Update
Hit 80mph on the highway today! It runs smooth with plenty of pedal left... gets moving real nice for a full time 4wd. I’ll eventually get an intake and 1406 for it but it’s “like new” and all stock except for the 268h, tfi and that’s ok!
Old 02-18-2018, 07:37 PM
SC/397's Avatar
Old 02-27-2018, 10:47 PM
gophman's Avatar
gophman gophman is offline
What cam would you recommend for my 360 in a j4500?
It already has an eddy intake, 600 Holley's and headers/dual 2.5" system? As far as I'm aware it's stock apart from that I have been thinking about an eddy performer grind or the 268 in your build.
Old 03-01-2018, 05:21 PM
SC/397's Avatar
I like the Performer grind in a 304. Not lopey or anything but they just sound healthy and they run well too. As I have stated before, the 268H or the Isky 270HL are my go-to cams for a nice cam that doesn't hurt low end torque, sounds good, and pulls hard from idle on up.
Old 03-17-2018, 08:04 AM
Fast Eddie Fast Eddie is offline
Comp Cam
I am running the 268H Comp Cam in my 360, what timing do you have your engine set at? Just wondered, I bumped mine up a bit and it ran much better.
THX
Old 03-17-2018, 09:07 PM
SC/397's Avatar
At least 10-12 degrees seems to be reasonable
Old 03-18-2018, 08:43 AM
Thanks ! I knew I was close!!!
Old 03-18-2018, 12:39 PM
DBX11's Avatar
10 initial
15hg @ 800 rpm
Old 03-27-2018, 03:00 PM
Thanks VERY much, reset timing and adjusted idle!! Runs better and starts great!
Very happy, pulls very nice thru gears and had it up to 85 mph on highway!!
Old 04-03-2018, 04:09 PM
Mephistopoles's Avatar
Mephistopoles Mephistopoles is offline
I've seen worse, still running.
78 Wag 401/TH 400
78 J-10 401/TH 400
69 AMC Rebel 2Dr/HT 401/TH 400
amc 360 vs dodge 360 Carleysjeep General FSJ Tech 37 05-13-2009 10:56 PM
AMC 360 to CJ 5 Swap CJ Runner Off-Road FSJ Tech 4 10-31-2008 10:52 AM
AMC 360 cam gear issues Cartman General FSJ Discussion 1 10-20-2008 07:00 PM
will a 2barrel carb off 360 fit 304? Robber80 General FSJ Tech 7 05-03-2006 06:39 AM
360 better than 258?? Scruffy Engine 6 07-24-2000 08:04 AM
