What model S10 donor for steering gear box?
  • Copenhagen1
    • May 01, 2007
    • 6
    I have done a lot of searches and read a lot of threads about changing the steering gear box out for an S10 version. I have seen where it has 3 holes instead of 4. I have read where it seems to steer a little tighter.
    But for the life of me, I cannot find what year S10 to look for. I read where it says "late model" but that doesn't help me figure out which one to order.
    I have an 85 GW that has developed a nice leak in the input shaft. I need to fix this because it is driving me crazy . Will my lines fit the S10 steering box or will I need new lines?
    Any help would be greatly appreciated .
    CH1
  • xsonmyeyes
    • Dec 13, 2004
    • 784
    I think 95-98 4wd but I could be wrong...someone else will chime in. Did you search the forum section??
    '91 Grand Wagoneer- New Long Block 05-10 W/ Edelbrock Performer Manifold, Carb, & HEI upgrade w/Taylor wires...and lotsa CHROME!--Chevy S-10 Steering box upgrade--3" body lift--31' BFG's
    2006 Harley Davidson 1200 Custom Sportster--
    2008 Harley Davidson 1200 Low Sporster
    '86 Chevy G20 Van
    '96 Pontiac Grand AM
    • flatbackdragon
      • Aug 22, 2003
      • 1965
      believe it was 94-2000 s10's 4wheeldrive, not 2.
      your lines will fit.
      "There's an inner idiot in us just waiting to climb out and romp about in unabashed stupidity, but most people retain just enough wit to keep the idiot bottled up."
      Gary Harmon-writer for Grand Junction Daily Sentinel (newspaper)
      Phil (or Flip, Dragon)
      Draco-79 Cherokee 360/QT-4" lift-pretty much stock and trying to fall apart
      • shepherdskeep
        • Aug 12, 2006
        • 277
        My Chero has a gearbox from a '98 4wd on it. As long as the FSJ is early 80's or newer the lines will bolt up. Older FSJ's (like mine) need to have the fittings adapted.
        -Rob
        Bluegill on www.4x4Grace.com
        79 Cherokee WT
        01 TJ Sport
        It's a Jeep thing!
        • flatbackdragon
          • Aug 22, 2003
          • 1965
          the three bolt box will hold up unless you run 35" tires and wheel hard than usual.
          If you want a four bolt box for jeeps NAPA has them
          NSP276528 cost 174. w/core charge of 139.00 unless you have your old one with you then no core charge
          NSP276507 is a three bolt jeep box 154.00 w/core of 11.01 (cheap core huh?)
          • shepherdskeep
            • Aug 12, 2006
            • 277
            That would be me, and my 3-bolt box is holding up just fine.
            Doesn't want to turn when the front tires are wedged against a rock that's bigger than my hood though
            -Rob
            79 Cherokee WT
            01 TJ Sport
            It's a Jeep thing!
            • Copenhagen1
              • May 01, 2007
              • 6
              Thank you guys. That was really fast. I will not be running anything bigger than 32" tires in the near future. I actually bought this Jeep to put on my deer hunting property and only drive during deer season.
              It runs great. I got all the windows and lights and everything working. I ordered new window seals (inner and outer) because it will sit outside. I ordered a fuel sending unit and got that guage working. I just need this dang leak fixed.
              After I replaced the window seals, I made a huge mistake. I washed it !
              Now , I think I am beginning to really like the thing and I may end up registering it and driving it. It is such a blast to drive. The seats are like big pieces of furniture.
              Thanks again.
              CH1
              • willysworker
                • Jul 27, 2001
                • 236
                napa box
                IMHO forget Napa's. I got a replacement box and it's junk. It's sloppy and only a couple years old. I will be replacing but not with another Napa unit.
                '55 Willys w/Chief chassis and running gear. 360,t18,d20,d44's on 33' BFG's. http://www.cardomain.com/ride/2451568
                • palexand
                  • Sep 05, 2009
                  • 347
                  Donor S10 year ranges ???
                  Hope I didn't miss the answer elsewhere here gang, but I'm looking for the definitive year range that the S10 gearbox can be had to fit the early '80's and up FSJ's (for sure)...it's not here.
                  I've seen people claim these years...and maybe others. I'd like the most recent from the recycling yard when going shopping tomorrow.
                  1. '94-'98
                  2. '94-'00
                  3. '94-'01
                  4. '96-'98
                  I ask because the car-part.com query when requesting a '98 s10 4X4 gearbox returns models from '95-'04...heck, if I could get an '04, I'd be better off.
                  -P
                  // How a carb's choke circuit works
                  // How to troubleshoot a carb's choke circuit
                  • Cannaert
                    • Sep 16, 2009
                    • 65
                    It is for a 95 to 03 4WD S-10. Same PS box. Autozone part # is 7577
                    82 to 03 2WD and 82 -94 4WD are different. Autozone part # is 7575 (ZQ8 is 7576)
                    I know my S-10s well. Been In love with them since the 4th grade.
                    Hope that helps out with what years you need to look up.
                    • shiner2001
                      • Feb 19, 2008
                      • 788
                      Thanks again.
                      CH1
                      Did you get the camo one with the huge bumpers that was on Craigslist in Mineola? I just saw "east Texas" and "deer season" so I figured that may be the one.
                      Derek
                      1973 Wagoneer 360
                      1978 Cherokee 360
                      1981 J10 360
                      1964 El Camino 357
                      1972 C10 454 LS6
                      1979 Corvette L82
                      1979 Scout II 345
                      1988 YJ 4.2L
                      1991 YJ 4.3L
                      1990 Suburban V2500 350
                      1998 Mark VIII 4.6L
                      2001 Yukon 5.3L
                      "If it's not broken, fix it 'till it is."
                      • shiner2001
                        • Feb 19, 2008
                        • 788
                        CH1
                        And to help out in the meantime, try Lucas's power steering stop leak. The 73 I just got the other day was leaking BAD (dry reservoir in about 50 miles, NO power steering) and I completely filled it with the Lucas the day I got it and have driven it since without adding any. Now, it still leaks a little bit, but it's a HUGE improvement over before. A smaller leak may be completely cured with the stuff.
                        Just something that may help you out until you get it replaced.
                        Derek
                        1973 Wagoneer 360
                        1978 Cherokee 360
                        1981 J10 360
                        1964 El Camino 357
                        1972 C10 454 LS6
                        1979 Corvette L82
                        1979 Scout II 345
                        1988 YJ 4.2L
                        1991 YJ 4.3L
                        1998 Mark VIII 4.6L
                        2001 Yukon 5.3L
                        • Headhoncho
                          • Oct 11, 2006
                          • 3632
                          I converted mine to an S-10 box and converted it right back a week later. Couldn't stand it. I wish you were closer as I'll make you a deal on my old S-10 box.
                          JR
                          1966 mustang fastback
                          '07 Dodge Charger 3.5
                          • shiner2001
                            • Feb 19, 2008
                            • 788
                            JR
                            Why did you not like it? I've been looking at doing the swap myself...
                            Derek
                            1973 Wagoneer 360
                            1978 Cherokee 360
                            1981 J10 360
                            1964 El Camino 357
                            1972 C10 454 LS6
                            1979 Corvette L82
                            1979 Scout II 345
                            1988 YJ 4.2L
                            1991 YJ 4.3L
                            1998 Mark VIII 4.6L
                            2001 Yukon 5.3L
                            • Headhoncho
                              • Oct 11, 2006
                              • 3632
                              It felt like the effort to turn the wheel was far greater than it was with the stock box. Felt like driving a truck with manual steering.
                              My truck has 37's with crossover steering and I can turn the wheel lock to lock with one finger with the stock box.
                              JR
