intake gasket
  • redwoody
    • May 16, 2010
    • 112
    intake gasket
    Replaced intake gasket set with rubber seals. Blow by has increased greatly. Any suggestions. has about 156,000 mi
    88 GW hei E-fuel pump 360 rebuilt- rv cam
  • redwoody
    • May 16, 2010
    • 112
    will check to see if pcv system is blocked
    • wiley-moeracing
      • Feb 15, 2010
      • 1430
      stock intake? may not have a good seal around the exhaust port for egr? or your motor is just worn out?
      • redwoody
        • May 16, 2010
        • 112
        Unhooked pcv tubing and catch can and blew air thru it all. Minor blow by now. stock intake thx.
