I always suspected there was a lot more gas in the tank after running out.
Today I removed my sender unit to repair a rust-broken ground tab. With the thing in my hand I noticed that when the float is all the way down, and the strainer sock off, the bottom of the suction tube is about 3" higher than the float.
Then I measured from the level of the o-ring to the bottom of the tank and compared that to the distance measured from the bottom of the sender flange to the end of the suction tube. Again about 3" distance.
When the sock is on the tube, it reaches to the bottom alright, but since its porous, then I'm still officially out of gas when the level reaches the bottom of the metal suction tube, but with 2-3 (?) gallons still in the tank. At least on my tank. Seems like maybe the suction tube should be longer.
Is this really the stock arrangement or is there a DSPO thing going on?
