Old 09-03-2017, 10:23 AM
FlashGordon's Avatar
FlashGordon FlashGordon is offline
Removal of Fuel Filler Tube Bezel ?
I am going to restore my '85 Wagoneer with original Dinoc 3M woodgrain. Will see if it still sticks. There is a production label from 1999 or like that on it.
I already removed the moldings which was very easy, took 15 minutes. I used a very simple "tool": kite-string
soft enough to make no scratches, thin and stabil enough to cut the old 3M tape as if it was like butter.
2 questions:
1.
I need to remove the "Fuel Filler Tube Bezel" now.
The metal part inside has no screws anymore (I expected to find 6 screws but probably removed in earlier years). the metal part is absolutely firm/fixed and does not dangle/wobble at all. Has anyone an idea how to try?
Or are the parts here in wrong order? Should the so called "TUBE, Air Filler" be behind the "Tube Bezel"?
https://goo.gl/photos/3LcqkubxQKK1nMAX7
https://photos.google.com/share/AF1QipM52NgHkiAskjpAY3FVsC8ICbFrzGy19W3vOExn86GFM_ N_IJ_v1OcoPfAUnHuVWQ?key=R1NjazV2Qm9ZUGJ1WFRvcU9uS zFhWXowaV9rQWd3
http://photos.google.com/share/AF1QipM52NgHkiAskjpAY3FVsC8ICbFrzGy19W3vOExn86GFM_ N_IJ_v1OcoPfAUnHuVWQ?key=R1NjazV2Qm9ZUGJ1WFRvcU9uS zFhWXowaV9rQWd3
http://https://photos.google.com/share/AF1QipM52NgHkiAskjpAY3FVsC8ICbFrzGy19W3vOExn86GFM_ N_IJ_v1OcoPfAUnHuVWQ?key=R1NjazV2Qm9ZUGJ1WFRvcU9uS zFhWXowaV9rQWd3
https://photos.app.goo.gl/gQsWOsS28gi8JkOi1
https://goo.gl/photos/w2HnueGsUzcb5qEu7
https://lh3.googleusercontent.com/uMxraVwB8JeqGQ9s-sNosEt8CU8JYenBnQYjiS_a6VzELr97l9n4DL0X9brxkY6HD6t 6CebP9tIui8JyIs6KDtSsFIgIf3n-ym38luU_tCTcwB67P4NPZizDlveVtaIJ80ech2d75Jjb8Fs1aI OPHop_abPLXzG3ikfkRoJoMk0XPMeN71f0FnE775Xkm8eBhfDj sE0ElRMfMz3hrXAPKTm3TvdY99ccP1MnJ0tGOO8LWUYCtm7-tthttqMI9eA-RiRWf7dVKKz178mT2JnBnO_56_TxN_h_v-NIWapef-xVUeaG8NYhD_ucJFtth9HvOL9kBN8SIdHTzr_YSbUwOfFMEtd8 QuNbHE_1Js2ppPOoscXk0CS_sGgCT_36uqIa0i5cavjUqugLZ4 i1rJ5As7DXlJE3ZK3OG7D4gZVMjyL0AvoUaSuMZeBR3YagCVWM 8wYMM_mFUJYeprP8e48M4TXaulqhDNvtgWyqozdItg8XN0b_hy YTN8n0YsydK6VODt9OgIo4zA-0emlNqmlUilpMR_jvb9ZsZmba7bj2yFu7d2zgSqO7SOk6HmBsw -AOTPSURV9UREo42T5HB1K6vA_Ik1IYdShzH8IzyFGTFGpyDMuM 6Oq7=w627-h437-no
https://goo.gl/photos/FhkMcXvyaZ62zGZt7
[IMG]
https://goo.gl/photos/NjAZZ5XF9S75e1AAA
[IMG]http://www.ifsja.org/forums/vb/[/IMG]
https://photos.google.com/share/AF1QipP186cAV1R5RdR5wsHqeidQvE8nSm9XWweayAYgwEp-kyneg3RAaydhChu7qfxEvg/photo/AF1QipM65w7dLJgvo0Z15ZrVnJcop0ixnHZrJnwRrNlr?key=Q nFlWGhlSHVxN1VmLUNTWWpSc0otNmR6R0N3X3hB
http://photos.google.com/share/AF1QipP186cAV1R5RdR5wsHqeidQvE8nSm9XWweayAYgwEp-kyneg3RAaydhChu7qfxEvg/photo/AF1QipM65w7dLJgvo0Z15ZrVnJcop0ixnHZrJnwRrNlr?key=Q nFlWGhlSHVxN1VmLUNTWWpSc0otNmR6R0N3X3hB
[IMG]http://www.ifsja.org/forums/vb/http://[/IMG]
2.
While it was very easy to remove the moldings it is more painful to clean them from the old 3M tape. I use different kind of putty knifes.
Has anyone also used some fluids (practical experience) to support this procedure and like to recommend this? I might use this for the car panels too...
https://goo.gl/photos/XBHjPFkJwXdXX1A27
https://goo.gl/photos/CxxhmmuqQ2GzHHTd9
best regards
Gunnar
Old 09-03-2017, 11:08 AM
Goo-gone removes most adhesives. Then rubbing alcohol to remove Goo-gone.
I use strong fishing line to remove any emblems with 3M and heat gun or blow dryer.
Heat with a lot of patience to peel off vinyl stripes.
Old 09-06-2017, 07:21 PM
shagwagon is right
use rubbing alcohol ( isopropyl ) after you
have removed adhesive
and,...if "goo-gone" or "goof-off" is not available where you are,
3M makes "adhesive remover"
comes in large tin container, will not harm paint.
good luck !
Old 09-08-2017, 08:12 PM
Goof off is stronger. More used for vandalism removal. I wouldn't use that it's too harsh.
Old 09-09-2017, 02:43 PM
...it works
yes, it works very good...
thanks
Old 09-12-2017, 01:30 PM
any idea regarding fuel filler tube bezel?l
am I am still wondering if the parts on my Waggy are mounted in wrong order?
it looks that the rubber-made bezel is inside and the steel-made fuel filler outside (visible) [see first picture]
but looking in the the parts-catalogue document I suggest, first comes the steel-made part and at least the rubber-made bezel... [next picture]
so if mounted in correct order I shouldn't see almost no steel-part anymore (and not as it looks on my Waggy's fuel tank opening right now).
I already tried to pull both parts out, but the steel-part does not move a single milimeter ....no screws in anymore ........ maybe with a little more power? ... but I am not sure if I would tear down other parts
I looked into Hayne's manual but found no description for that
If you have any suggestions I would like to follow them...
have a nice week
Gunnar
Old 09-15-2017, 10:13 AM
Your pics don't show...
There are rivets holding the steel cup to quarter panel.
IIRC they must be removed to allow complete removal of the filler tube assembly from quarter panel.
You can grind them off from backside inside/behind cargo panel.
Old 09-17-2017, 01:49 PM
rivets
thanks,
have seen the rivets now when removed the rear-panel in the trunk.
it looks that it will be will removed then out of the fender
before I obviously have to detach the rubber- hoses from the metall filler tubes....
Old 09-17-2017, 04:13 PM
Frank G's Avatar
Frank G Frank G is offline
I looked into this and it appears that you have to remove the two lower hoses from the bottom of the rear quarter panel underneath the jeep.
I have a brand new bezel to install but it appears that it's not going to be that easy LOL. As to just unscrew the 6 or so screws.
The metal that you're looking at with the screw holes is attached to the fuel filler itself it's one piece.
In the picture #5. is all one piece. #4 is just a rubber gasket that may or may not be there for my experience.
Frank G
15 X Jeep Owner
15 WK2 Limited-Daily Driver
15 WK2 Altitude-Wife's
94 ZJ Laredo - 5.2l , Leather, Tow
87 SJ - Restored
86 XJ Laredo - Restored
44 Willy's MB -Restored
Previous Jeeps: ALL MISSED
14 WK Limited 09 KK Limted 11 WK2 Laredo 08 JK Sahara 05 WK Laredo 01 WJ Laredo 97 XJ Sport 95 XJ Sport 84 XJ Chief
Old 09-20-2017, 02:04 AM
fuel filler tube removal
thanks Frank,
yes I have seen the rubber hoses on the inner fender side and the smaller metal plate (where the hoses are going through) that is mounted on the inner fender side, too.
And from inside the trunk, behind the cargo panel, I have seen now also the rivets which holds the one-metal-filler-part (#4 on picture).
OK, so I know now HOW to do and will consider the next days IF I like do that.
(I already have a new bezel and a new bezel gasket. And I should change also the rubber hoses too at this opportunity)
Thanks for your help guys
Fuel sender suction tube too shallow? Rich88 General FSJ Tech 11 05-03-2011 11:14 AM
Oil Vapor Coming From 360 Oil Filler Tube DonC General FSJ Tech 11 05-23-2009 10:50 PM
Vapor Lock?!? 88sunroof General FSJ Tech 2 08-02-2008 06:07 PM
Electric Fuel Pump BigAWagoneer General FSJ Tech 3 03-05-2005 11:12 AM
Fuel Filler Tube Stuka General FSJ Tech 14 05-08-2003 04:03 PM
