So I'm back looking at some rear tank options (I know this topic has been exhausted and I have searched both hear and the mothership.) I really want to get rid of my coffin tank to free up room. I don't care for massive tank capacity at this time, to expensive to fill anyways. It looks like a 90's f150 is a great, and cheap, option http://www.summitracing.com/parts/sum-255012/overview/year/1993/make/ford/model/f-150 . Tucks in very tight and looks like its been done many times successfully. I'd also be open to the blazer swap but it sticks down a bit more than the f150. All the swaps I could find were done on EFI engines. I have a stock carburated 360. Anyone know what sending unit/fuel pump is compatible or any other info on this swap?
F150 rear tank
If you're hoping to use your stock 89 gauge you'll need a sender that reads high resistance at full and low resistance at empty. Your 89 gauge/sender is set up for 88 ohms full, zero at empty. If the Ford tank has an EFI pump in the tank you'll need to install a pressure regulator. An EFI pump w/o a regulator will pump more fuel than your carb can handle.joe
Originally posted by joeIf you're hoping to use your stock 89 gauge you'll need a sender that reads high resistance at full and low resistance at empty. Your 89 gauge/sender is set up for 88 ohms full, zero at empty. If the Ford tank has an EFI pump in the tank you'll need to install a pressure regulator. An EFI pump w/o a regulator will pump more fuel than your carb can handle.89 GW- Rebuilt 360 w RV camshaft, 6 inch lift, de-smogged, 14 bolt, HD44, 35" tires
im putting a 31 gallon suburban tank in the rear of my j10. Choice of efi ro standard fuel pickup. going with the stock sender. I have speed hut gauges so I can set the fuel anyway I want to. Hopefully soon it will be painted and I will snap some pics of my tank.1980 J-10<br />Rusty\'s 4 inch lift<br />2 inch body lift,<br />35 in Xterrains on J20 axles<br />4:30 gears<br />Detroits<br />In-Cab cage thru the dash
Originally posted by j10jimim putting a 31 gallon suburban tank in the rear of my j10. Choice of efi ro standard fuel pickup. going with the stock sender. I have speed hut gauges so I can set the fuel anyway I want to. Hopefully soon it will be painted and I will snap some pics of my tank.Last edited by surfwagoneer; 09-06-2014, 08:56 PM.89 GW- Rebuilt 360 w RV camshaft, 6 inch lift, de-smogged, 14 bolt, HD44, 35" tires
Info I pulled from a stock replacment sending unit from Oreillys http://www.oreillyauto.com/site/c/de...l+sending+unit
Resistance When Empty (Ohm): 0 Ohm
Resistance When Full (Ohm): 110 Ohm89 GW- Rebuilt 360 w RV camshaft, 6 inch lift, de-smogged, 14 bolt, HD44, 35" tires
surfwangoneer, I have less than $200 into the brand new tank, pickup unit and straps. I didn't want to spend a ton of money and this should work out pretty good.1980 J-10<br />Rusty\'s 4 inch lift<br />2 inch body lift,<br />35 in Xterrains on J20 axles<br />4:30 gears<br />Detroits<br />In-Cab cage thru the dash
Originally posted by j10jimsurfwangoneer, I have less than $200 into the brand new tank, pickup unit and straps. I didn't want to spend a ton of money and this should work out pretty good.89 GW- Rebuilt 360 w RV camshaft, 6 inch lift, de-smogged, 14 bolt, HD44, 35" tires
