Old 09-12-2020, 08:20 AM
elskeptico's Avatar
elskeptico elskeptico is offline
Paint prep hell
This is just a general venting post about how difficult paint prep is on these things. I had no idea.
I underestimated both how much rust I have on my Chief and how much work it is to eliminate it. Holy smokes. I started digging into the old seam sealer (of which there is plenty) and inside nearly every inch of seam is more rust. It
1979 Cherokee Chief S, 360, TFI, Part-time conversion, rust
If you go lookin' for rust, you'll find it.
Old 09-12-2020, 08:41 AM
yah these things rust like the mufflers on a 70's honda motorcycle.
Old 09-12-2020, 09:22 AM
yes,
and I have always said a paint and body man
earns every penny they make.
it is a bear but the hard work will pay off
always heard it said that
a paint jobs success is 95% what is under the paint,.....the prep.
Old 09-12-2020, 09:09 PM
Crankyolman's Avatar
I ran into the same thing on my truck, it was a huge pain but eventually you will get there and have something to be proud of.
'72 J4500
Old 09-13-2020, 08:58 AM
brielly's Avatar
brielly brielly is offline
Yup, get ready to scrape every bit of that seam sealer out. Unfortunately you wont be able to remove the rust deep in the seems so some por15 or equivalent would be good to put in those areas before the new seem sealer. Good luck, your hard work will pay off.
For Sale Custom built reproduction Rhino Grilles http://www.ifsja.org/forums/vb/showt...24#post1676924PM me for details or email rrielly@verizon.net
1982 Cherokee Chief 258 6 cyl, AX-15, NP208, mopar mpfi, hydroboost brakes.
1983 Jeep Cherokee Laredo 258 6cyl*SOLD*
Old 09-13-2020, 06:36 PM
Tripwire's Avatar
Tripwire Tripwire is offline
just wait till you remove the windshield i almost puked when I pulled mine
Abort? Retry? Ignore? >
Old 09-14-2020, 11:07 AM
Oh man, and all the little lines, and curves, and angles. When I see a FSJ with arrow straight lines and perfectly flat areas that are supposed to be perfectly flat, I know someone spent years of man labor sanding on that rig.
Old 09-16-2020, 07:18 AM
elskeptico's Avatar
I knew I'd find solace here. I appreciate the encouragement. Full steam ahead. Starting body filler this week!
In each corner of the windshield frame, there are these square pockets, and I don't know what was filling them before, whether it was seam sealer or part of the sealer that's used with the windshield seal. Anyone know if these should be filled in?
WTF happened to my paint! ZackN920 General FSJ Discussion 11 12-29-2018 12:46 AM
ISO a Prissy Paint Job asudchiman FSJ-PRIS 21 12-19-2017 12:36 PM
Paint prep, crevices hidden areas, GREASE Beach_Dude General FSJ Discussion 4 09-27-2016 10:45 AM
Rust paint test who is the best of these 5 Kaiserjeeps General FSJ Tech 11 06-24-2016 04:41 AM
Roll on paint jobs? FSJeeper General FSJ Discussion 18 10-03-2007 08:53 PM
