Transmission fluid cooler needed??
  • Trooper13
    • Nov 29, 2016
    • 8
    Hi there,
    My son rear ended someone in my '88 GW and wrecked the grill, A/C condenser, transmission cooler, and radiator.
    A/C didn't work anyway, so was not too worried about that. But since I had to get a new radiator anyway, I went with a heavy duty, 3 row. Takes up more room than the stock one, but fits OK.
    Since I now have a larger radiator, do I even still need the extra transmission cooler? Or will running it just through the radiator do the job? I don't know if the extra cooler is stock or an add on/upgrade. I won't be towing anything if that matters.
    Thanks!!
    '88 GW w/reman Jasper 360
    Howell EFI
  • 440sixpack
    • Jul 21, 2016
    • 612
    If you're not doing hard towing the add on cooler is a waste of time.
    • tgreese
      • May 29, 2003
      • 11682
      Yes, factory cooler in the radiator is fine for normal driving.
      • letank
        • Jun 03, 2002
        • 4129
        my take on this subject is an external cooler is a must, when you see how high the temp can go with an external cooler, and how slow the transmission oil temp decrease on a 3 mile downhill after a 3 mile uphill, I am seriously thinking of bypassing the built in radiator coolant fof the straight external cooler.
        Remember that vehicules are built to sustain their reliability not further than the covered warranty.
        • babywag
          • Jun 08, 2005
          • 10288
          An external cooler is cheap insurance to keep an old tranny happier/longer.
          Way cheaper than repairing one after overheating fluid.
          • ShagWagon
            • Apr 10, 2016
            • 871
            Aren't they like less than $20 and they even include zip ties to mount in front of your radiator?
            • Trooper13
              • Nov 29, 2016
              • 8
              Yeah, they are pretty cheap. It's not the money. I figured it would just be one less thing that can leak if I didn't need to use that cooler.
              Howell EFI
              • 440sixpack
                • Jul 21, 2016
                • 612
                Everyone knows more than the manufacturer it's always been that way.
                Ditch the cooler if you're not heavy towing it's as necessary as most of the other JC Whitney treasures.
                • PlasticBoob
                  All Makes Combined
                  • Jun 30, 2003
                  • 4007
                  It depends on where you live. Down here where it regularly gets over 85*F, and pushing around 32" tires, I would definitely recommend it.
                  I have an 8-pass tranny cooler (with a 14" pusher fan on top of it) and a tranny temp gauge, and the cooler has made all the difference on warm days.
                  If you don't believe me, hook up a gauge or get an infrared thermometer and check the lines for yourself after a lot of stop-and-go or uphill freeway driving on a warm day: you'll find uncomfortably high temps, like I did.
                  Rob
                  Click for video
                  • Fasts79Chief
                    • May 09, 2018
                    • 55
                    Always. Regardless of if you tow, or heavy loads, or whtever ... a trans cooler is mandatory on older vehicles in my opinion ... if you want your trans to live.
                    It's not a 'belt and suspenders' approach ... it's your pants.
                    1979 Cherokee Chief S
                    Saxon Yellow
                    360, TH400, Edelbrock everything, 33 x 10.50 x 15
                    Loaded
                    Will let you know when I know what else it has. lol
                    • Ristow
                      • Jan 20, 2006
                      • 17292
                      i usually bypass the rad cooler and just run an aux. cooler.
                      Originally posted by Hankrod
                      • tarriverarms
                        • Apr 21, 2016
                        • 45
                        I thought the external cooler was stock? Getting ready to replace mine as the fins are loose and flimsy. Well actually going to repair AC and since the radiator has a busted weld on the mounting bracket I am going to replace all three coolers.
                        Is there one anyone can suggest or recommend over the other?
                        • Ristow
                          • Jan 20, 2006
                          • 17292
                          stock on the tow package,as i recall. any of the hayden aftermarket are good.
                          • mattmopar440
                            • May 17, 2007
                            • 4092
                            Same that way engine temp doesnt effect the transmission temp and if a external breaks u have a small fluid leak and if an internal breaks your normally looking at a transmission
                            87' Grand Wagoneer
                            401/727/229, Currently:RUNNING
                            84 J10/20 hybrid 258/727/208 Daily Driver
                            80' J10 4BT/AX-15/208
                            74' J10 Go Grabber Green Sold
                            Originally posted by Heavy_Metal_Thunder_81
                            Inferior Chevy
                            • rang-a-stang
                              • Oct 31, 2016
                              • 5512
                              Where did you hook up your gauge sensor? Trans pan? Cooler input? cooler output?
                              Chuck McTruck 71 J4000
