Old 05-05-2019, 06:27 AM
fsj454 fsj454 is offline
Long time member
WOW 150.24$
1 acc-8220acc . 1 msd 31859 . What is this world coming to $$$$$$$
Old 05-05-2019, 05:59 PM
What do you do with the boot for #7 on that MSD cable set?
The boots are so long it forced the cable to rub against my master cylinder in both wags I had. It only takes a few thousand miles for the insulation to start rubbing away, and now 20,000 miles later it's through the red layer and into the yellow. Is the boot was just an inch shorter it wouldn't be a problem.
Also, I agree - SO EXPENSIVE.
1984 GW
360
Comp 260H
Magnum Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
Old 05-05-2019, 06:44 PM
take a very close look @ rotor rivet on that accel turd.
I had one come off and leave me on the side of the road.
last Accel part I ever bought...overpriced junk IMHO.
Standard Motor still makes good caps/rotors and half the cost.
Old 05-05-2019, 07:34 PM
Long time member
boots
About the boots . The super conductor 8.5 mm wires have boots that you bend to any angle in any direction . I have these same wires on my Cherokee 454 with headers with bendable spark plug boots no burnt wires I am very happy with this product .
Old 05-06-2019, 05:41 PM
Long time member
rotor
I looked at rotor today .... No rivet no they put a Philips screw .
Old 05-06-2019, 06:38 PM
Check and make sure they used loctite?
I suspect the reason mine came apart was possibly because of the cap terminal to rotor clearance.
@ any rate the kit went back to summitracing for a refund.
Based on other folks having problems with their products sealed the deal for me.
Never again...
Old 05-07-2019, 11:07 AM
I bought acel wires and swapped them for MSD. They would come apart every time trying to remove them off the spark plug...
Old 05-07-2019, 11:13 AM
Funny had same issue with some Accel wires...Turds!
MSD is ok, Accel is not imho.
Old 05-07-2019, 12:38 PM
I got nothin regarding your $$$$ concern. I will add that Accel "USED" to be good stuff decades ago but somewhere around mid-late 70's(?) their quality went to crap.
So bad so I'm really surprised they still even exist today. If you get nothing else out of this thread: STAY AWAY from anything Accel!
Old 05-07-2019, 04:56 PM
Long time member
Accel
I purchased 3 sets of accel 9000 ceramic spark plug wire sets #9002C .. aND LET ME TELL YOU those are junk WARNING . MSD Wires are 10 times better no burnt wires or misfires..
Old 05-08-2019, 04:15 PM
HAHAHA!!! I always thought Accell was the generic crap at McParts! You get what you pay for.
