so the first day i got my cruise control hooked up it worked great. i was not done with the rest of the harness but it worked none the less. now it isnt working. i have found many problems with it and fixed all of them but still nothing. the plug on the engine compartment side of the firewall was unplugged, plugged it in. ground came loose, grounded it. columb plug seemed loose, re inserted it and it was tighter. im confused it just dosent work. ideas?
cruise control issues after new wire harness install
87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
True Dual side pipes
TF 727 & np229
B&M Shift Kit
12 Bolt rear & D44 front
4.10's and ARB lockers
SOA & shackle flip
33 12x5's
Empty wallet
Tags: None
checked all vacuum lines and even replaced a questionable one and there all good and connected. any other ideas?87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
TF 727 & np229
B&M Shift Kit
SOA & shackle flip
33 12x5's
Empty wallet
Other than that it is plugged in how yould I check it?87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
TF 727 & np229
B&M Shift Kit
SOA & shackle flip
33 12x5's
Empty wallet
You can unplug it and check it with a multimeter. With the sensor disconnected from the speedometer cable you can spin it by hand and see if the values change on the multimeter. Also, since you have been doing a lot of wiring and plugging and unplugging connectors, you might need to recheck any fuses related to the cruise control if you haven't already.1991 Grand Wagoneer
1967 J-100 Panel Delivery Military
i dont understand? unscrew both sides of the speedo and turn the sensor by hand?87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
TF 727 & np229
B&M Shift Kit
SOA & shackle flip
33 12x5's
Empty wallet
probably a waste of time the odds it's the sensor very low.
You have to remove the cables from the tranny & then it will turn. 90% chance that isn't the problem. Unless you knew you did something to damage it.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
i did pull it out by accident but then it went back in. but my speedometer works so ???87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
TF 727 & np229
B&M Shift Kit
SOA & shackle flip
33 12x5's
Empty wallet
i wanna swap the module and see if thats the issue. though i dont see why it would be. i went back through everything today. everything is connected and getting power. no vac leaks im not getting it...87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
TF 727 & np229
B&M Shift Kit
SOA & shackle flip
33 12x5's
Empty wallet
