Old 08-31-2012, 05:02 PM
bd 75's Avatar
bd 75 bd 75 is offline
t 18 ?
Got a ? Fellas. How do ya remove the shifter from the trans. Do ya take the whole top plate off, and if so is there a trick to it.78 t 18. Thanks
78 Cherokee 360 4 speed Dana 20
Old 08-31-2012, 05:13 PM
Stuka's Avatar
Stuka Stuka is offline
You unscrew the cup thats at the base of the shifter, then there is a pin under that that you need to push out.
Be careful with the cup as it has pretty fine threads and is easy to mess up.
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 08-31-2012, 05:16 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
And don't drop the pin down in the trans.
aa
Anthony
1983 J-10 - 4.6L(MPFI)/CS144/NV3550/D300/44/44/3.54/32
1983 Honda CB1100F
1983 Honda CB1000C
Old 08-31-2012, 06:36 PM
bd 75's Avatar
t 18
Thanks a ton guys. I thought the cup could do that or pop off
But didn't try that yet. Thanks again
Old 09-01-2012, 11:07 AM
KJ Ryu's Avatar
KJ Ryu KJ Ryu is offline
Anyone have a diagram? My shifter literally fell out in the first week that I owned my truck. I put it back together and keep an eye on the cap now, but would like to replace the pin. Didn't know there was one. I've changed the oil in it a couple times and never seen any bad signs so it was probably left out by a PO at some point.
Ron
2005 KJ, Hit-n-Run, 2am 6-17-2012, Totaled.
1977 SJ J10, 2v304, T18, D20, 37x14s, SOA & SF on tons, still ugly waiting on clutch
1978 SJ Wagoneer, 360, QT, 33x12.5s, lift by Sawzall NOT Running
1993 D150 "1-legged dog"DD
Originally Posted by Mars
One man's trans leak is another's penetrating oil
Old 09-01-2012, 11:49 AM
If you can't find one online PM me your email and I'll send the diagram of the top section.
-Geoff Hill
Old 09-01-2012, 05:13 PM
KJ Ryu's Avatar
Thanks, Joe. The top section diagram seems to be very elusive. Wasn't sure there even was such a thing.
Ron
Old 09-01-2012, 05:26 PM
T18 top from the parts book.
http://nmr.mgh.harvard.edu/~reese/T18top.PDF
The pin is item 7.001-4
Old 09-01-2012, 05:52 PM
KJ Ryu's Avatar
Ok, I remember that. Had to align the slot on 7.001-1 with it to get the shifter back in so it's still there but, maybe just not tight?
Ron
Old 09-01-2012, 09:32 PM
Stuka's Avatar
The purpose of the pin isn't to keep the shifter it, it is to keep it from spinning.
