Distributor gear alignment
  • Pyrate2010
    • Sep 18, 2015
    • 23
    I want to reuse my distributor gear but the holes for the roll pin don't line up. I have tried two different distributors and neither one lines up with my old gear. The hole is off by about one-third of the diameter, I was wondering if I should just redrill the hole and use a bigger pin or perhaps just put a little plug weld in the hole what do you guys think. Thanks Joe
    1983 Cherokee 4 door
    AMC 360 727 trans 229 transfer case
    FiTech EFI, MTA-1 cam, wiseco 9.25 pistons
    Working on complete restoration with Wagoneer boobie Grill
  • babywag
    • Jun 08, 2005
    • 10288
    what type distributor?
    • Pyrate2010
      • Sep 18, 2015
      • 23
      Stock duraspark replacement reman.
      • babywag
        • Jun 08, 2005
        • 10288
        probably an aftermarket gear like MSD?
        @ one point they were made out of spec.
        They were little taller than OEM gear IIRC, which caused alignment issue.
        Measure gear that came on reman. against yours see if that?s issue.
        Probably have to drill new hole then to keep/reuse
        Make sure end clearance is ok, and drill away I guess.
        • TexasJ10
          360 AMC
          • Jan 03, 2002
          • 2774
          The distributor in my j20 was drilled with the hole at a slight angle. The gear would only line up one way to reinstall the pin. I assumed it was one of those Friday afternoon manufacturing things at the plant.
          • Pyrate2010
            • Sep 18, 2015
            • 23
            The fiirst new distributor that I got the hole was drilled at an angle also and so I returned it and tried to get a better one. the second one the hole is way up towards the gear and doesn't fit. I don't have a drill press ,so I am hesitant to attempt to drill it myself
            • fulsizjeep
              • Aug 21, 2002
              • 22496
              I had a local machine shop that is familiar with rebuilding AMC V8s drill the distributor shaft on 2 of my HEI distributors for $20. Two for $20. The shop owner is familiar with the proper gap for the bushing between the gear and the bottom of the distributor housing. I sure don't have the capacity to do this at home.
              • babywag
                • Jun 08, 2005
                • 10288
                They're dirt simple to rebuild if you have the original OEM/AMC one around somewhere?
                A single bushing in the bottom of housing, new pickup coil/reluctor, and a working vacuum can. Maybe new advance spring kit.
                Maybe use all new stuff from reman, but use an original shaft?
                Clean it, lube it, install new stuff, good as new.
                • Pyrate2010
                  • Sep 18, 2015
                  • 23
                  Thanks for the reply guys, swapping out the distributor shaft with my old one is a intriguing idea. As far as drilling it out at home yeah I'm not sure if that would be such a good idea or not, perhaps a machine shop would be better.
                  • babywag
                    • Jun 08, 2005
                    • 10288
                    I?d rather use an original OEM used part vs. a reman of obvious poor QC.
                    Reman parts and new parts are a crap shoot these days.
                    Get the distributor gear clearance or alignment wrong = gear chewage and hours of fun disassembling front engine to replace gear set.
                    Your call, but I know what I would do.
                    • Pyrate2010
                      • Sep 18, 2015
                      • 23
                      Babywag, thanks for the idea to swap out the shaft it was really easy like you said, hopefully it will work out okay. I guess I'll find out in a couple of weeks when I fire this thing up for the first time.
                      • roddiaz1
                        • Mar 01, 2014
                        • 7
                        Duraspark distributor disassembly
                        Are there any instructions or videos on how to disassemble a duraspark dizzy to the point of extracting the shaft from the body? I can only find instructions that go as far the reluctor (spelling?).
                        I'm having the same issue that the new dizzy's roll pin hole is centered whereas the original distributor has a slightly off-center hole for the roll-pin. Therefore the original gear (macthed to the gear on the crankshaft) will not intall into the new dizzy.
                        I thought of the dilling a second hole at 90 degrees from the original, but I'm affraid to do so. Perhaps a machine shop could do this, but I'm not familiar with any in the area. So the shaft swap is an appealing approach if it is not too involved.
                        Thanks,
                        Rod
                        • babywag
                          • Jun 08, 2005
                          • 10288
                          once gear is off and reluctor & pickup plate removed whole assembly just comes out.
                          ristow has pics in engine tech archives if you can't figure it out.
                          i set the distributor up for the plow truck engine tonite,same way i do all of mine. mine all burn 87 octane without ping/detonation,and i run 12~15 degrees intial advance and manifold vacuum to the advance unit. so,here's the way i set mine up... my engines are fully stock,or 4 barrel holley with edelbrock performer grind
                          • roddiaz1
                            • Mar 01, 2014
                            • 7
                            Perfect!
                            Thanks for the link. Just what I needed.
                            Rod
                            • jeepman1
                              • Jul 22, 2015
                              • 421
                              I had to turn a summit dizzy 90 deg. then drill and pound pin in w/ 8 lb hammer. Still haven't started my engine but I'm getting close. I used orig gear and think I got it pretty close..
                              I need to find out what wire to run to this HEI dizzy now..
                              : 98 9er
                              '83 Honcho j10
                              '12 Liberty Ltd.. wifes
                              '19 Chaparral H2o Dlx sport 21
