I want to put these on today (Bulltear cast aluminum valve covers) and the stock bolts from the stock stamped steel valve covers are too short... longer bolts from the hardware store will work, yes?
Bolts for Cast Aluminum Valve Covers
That's what I did for the covers on my 455, used stainless and had to cut them down slightly so they didn't bottom out before they snugged down.*** I am collecting pics and info on any factory Jeep Dually trucks from the J-Series at the new Jeep Dually Registry.
Use studs, They are much much better
Baltimore
1991 Grand Wagoneer, Rebuilt 360, Eddy Perf Manifold, Razor Grill
1970 Plymouth 'Cuda (my baby)
