Crap, you're right Tim. Thanks for catching that. The Jeep NP231, at least, is left drop, while the old D20 is right. Not sure what the easiest right drop NP pattern t-case would be, but there are certainly some options there. You could swap the front axle (not terrible, if you can find a cheap donor), use an adapter to keep the D20 (expensive?), or pick through the various GM NP pattern t-cases to find something you like. I know the GM NP208 of the 80s was right drop, but I believe it had a slip-yoke, so you'd have to deal with that. You would likely have to swap the input gear for a 23 spline one, as well.
aa
aa
