Old 12-06-2017, 11:24 AM
Chris R's Avatar
Chris R Chris R is offline
Noob!
J20 Camper shell question
Getting ready to fit an original Jeep camper shell on my J20 for the winter. What type of material/barrier should I use to place between the shell and the top of the bed? I do not want to put anything down with adhesive and not anything that gathers and holds moisture. Any thoughts would be appreciated.
Thanks
Old 12-06-2017, 11:50 AM
I got the Willys....
I used a 3/8" or so thick black foam indoor/outdoor weather stripping made for caps. I picked it up as Autozone if I remember right. I had to buy two rolls. This was for a factory Jeep/Leer cap I put on my 63. Sealed well. It's adhesive on one side but has a backing paper you don't need to remove.
Similar to what Lowes has here.
https://www.lowes.com/pd/M-D-10-ft-B...rstrip/3120623
1971 Gladiator J2000 Platform-Stake Dump 350/T18
1968 Gladiator J3000 3406Z 160" wheel base DRW 350/T18
Old 12-06-2017, 03:32 PM
Don't over think this. There are a ton of weather strip seals out there. Pick one you think works for you. My 73 came with a topper till I finally found someone (an RV shop) to give it to. It had some stick-on black rubber/foam strips on the rails. Yeah 1/2 hr clean up time once the cap was gone. I survived the clean up drill just fine but when installed it never leaked and I live in rain country. It's simple cap weather strip material not space age exotic shuttle door gaskets. The link Thomas provided should work well for you.
Old 12-06-2017, 03:46 PM
Chris R's Avatar
Noob!
Perfect! Thanks guys.
Old 12-06-2017, 08:31 PM
You can always glue the seal to the cap and not the bed. I glued it to the bed simply because it's easier, but have gone the other way around in the past.
Also, I needed to use a thicker piece on the front bed panel. My Jeep caps front flange is a bit higher than the side flanges.
Old Today, 11:26 AM
camper shell seal
good idea kaiserman
( on affixing it to the shell not the bed )
my only advice that may/may not help
is to use CLOSED CELL foam
it will not absorb moisture
like an open cell foam would.
J-20 with factory shell .....SOUNDS AWESOME.
1990 grand wagoneer
1974 J20 emergency brake question Jeepdawg General FSJ Tech 5 09-12-2016 08:36 AM
J20 Axle flange gasket question ? my 2j20's General FSJ Tech 7 02-02-2015 12:10 PM
J20 tire/wheel swap question jeepmandave General FSJ Tech 9 09-23-2014 09:01 AM
J20 Axle Question 1975_jeep_j10 General FSJ Tech 2 07-01-2013 09:07 PM
