My .02 is same color with a wide say 5" cream white stripe with a 1 1/2" stripe below it about the height of the door handle.
'77 J-10 360 Rescue-Budget build
Originally posted by azmtn04My .02 is same color with a wide say 5" cream white stripe with a 1 1/2" stripe below it about the height of the door handle.Mark
Stock '77 J10 Pioneer LWB
360 V8, 2bl (49 state)
T-18 4 speed
Dana 44's
31x10.50x15
Originally posted by Fort Wayne FrankI agree, great looking truck! I have a "tawny orange" 77 J10 that needs some, where did you get the paint? Thanks.
Maybe someone on here has dealt with them and can chime in as to how their experience was.Mark
T-18 4 speed
Dana 44's
31x10.50x15
Finally able to get back to the project! Decided on new original style radiator. Also installed new battery, all new vacuum lines and hoses, distributor cap and wires, new used 31x10.50 tires the neighbor had for sale, and I rebuilt the carb with a kit from Mikes Carburetors.
Seems to run real well. Time for moment of truth. Have appointment at smog shop tomorrow . Wish me luck!
Mark
T-18 4 speed
Dana 44's
31x10.50x15
Good luck!!!! Can't you get antique plates and avoid the smog check?1963 1414 Armstrong Power Steering & Windows, no radio/reverse lights/hazards/seatbelts
1993 Chevy Caprice Wagon -1971 Honda CL175 - 1978 Honda CX500 - Bobcat 610
Gone but not forgotten:
1975 Chevy Impala Sport Coupe; 1933 Chrysler CQ coupe; 1970 AMC Ambassador Wagon; 1985 Chevy Caprice Wagon; 1975 Starcraft Holiday18 w/1976 Evinrude 70hp
Originally posted by KilroyJCGood luck!!!! Can't you get antique plates and avoid the smog check?
Also, getting the historic vehicle plates (that's what CA DMV calls them), is a huge pain and then you are restricted on what you can use the vehicle for. Parades, historic vehicle clubs rallies, etc. Not as a daily driver. If I am remembering this correctly they have a limit on how many miles you are supposed to drive it per year.
I tried to get my truck registered as historical vehicle and after many trips to the DMV I gave up because I found out you still have to pay the normal vehicle registration fees with a truck PLUS the historic vehicle plate fee. This is because every truck in CA is considered a commercial vehicle so you have to pay an additional fee based on the GVWR. Basically another way to get more money out of you even if you do not use your truck for work or ever haul anything in the bed.
Rant off! I wish you luck at the smog shop!
Thanks KilroyJC...
Amen to that tgomes! Draconian says it all. I'm all for clean air but stupid is just stupid. Ah well... at least out here we don't have to put up with everything but the tires rusting into oblivion! My neighbor tells me the rolling 30 year thing is being considered again cuz all the smog shops are complaining about having to test these old relics. Ehh.. Not gonna hold my breath for that one.Mark
T-18 4 speed
Dana 44's
31x10.50x15
Take the good with the bad I guess, it is nice that rust isn't so bad here.
Let us know how the smog test goes!
Passed! The C.A.R.B. gods have bestowed their blessings on me. (barley)
Results..
HC @ 15mph - Max: 319 Average: 76 My Truck: 319
HC @ 25mph - Max: 269 Average: 64 My Truck: 242
COs very good, way under average... NO also way under average.
The tech said he thought hydrocarbons high due to a lean condition. Sure enough when I got home I did some checking and discovered the new thick felt like gasket under carb base had compressed and the carb base had loosened significantly. I tightened her down and she runs even better now!
Dodged a bullet there! Off to dmv for tags then a good long road test.Mark
T-18 4 speed
Dana 44's
31x10.50x15
CONGRATULATIONS!!!!!
No, never lived in CA. Originally from NJ - you know,the state that decided we needed MTBE in our gas AFTER CA said to take it out...1963 1414 Armstrong Power Steering & Windows, no radio/reverse lights/hazards/seatbelts
Originally posted by KilroyJCNo, never lived in CA. Originally from NJ - you know,the state that decided we needed MTBE in our gas AFTER CA said to take it out...
Auburnmark, what are you doing next with the truck?
Originally posted by tgomes1987Auburnmark, what are you doing next with the truck?
My goal was just to get this thing running and drivable to make sure it was a sound enough truck to get CA legal (smog and registered) before I put to much time and money into it. I still got to go thru the brakes (they work fine but old and crusty) and I have a little throw-out bearing noise when cold.
Other than that the motor seems real strong and no other issues I know of.
Options I have been contemplating:
* Sell it and buy something '75 or older (smog exempt) so I can build the motor the way I want to.
* Keep it the way it is and just use it for what it was meant for.. a utility vehicle to haul stuff, dump runs, etc.
* Throw a lift kit under it and go wheel the crap out of it.. something I've never done much of but would like to.
* Rebuild/restore. Strip down body and interior and repaint, re-upholster,
etc. (Also fun.. but expense and room to work are a problem).
Guess I'll just let this percolate awhile and see what comes.. Suggestions/opinions welcome.Mark
T-18 4 speed
Dana 44's
31x10.50x15
Nice truck glad you rescued one! Hard decision to just use or restore or beat on. I always wanna lift mine and then I look at it and think, it looks like it did from the factory for the most part and that's why they all got sold simply cause it's a truck. A utility vehicle with a quadratrac system for job site transportation thru mud hills etc. low enough to easily load a sheet of plywood and cut it up right there on the tail gate if need be.
Just use it and keep it running for the next guy and usually the closer it is to stock the easier it is to work on vs PO hacks/work arounds Have a nice day
