Old 04-20-2019, 09:07 PM
GWJeeper GWJeeper is offline
Door Lock Grommet Question
So I ordered a set of lock knob grommets from TGW and trotted out to install them. I tried using a socket and small hammer to drive them down into position but no luck. I'm guessing that I'm going to have to pull the upholstery etc off the door, remove the wood grained piece that borders the glass then push the grommet down into place and bend the tabs out to hold the grommet in the correct position. Can anyone confirm this?
Old 04-21-2019, 09:20 AM
do not attempt removing upper woodgrain on doors, it won't end well.
if they don't fit i would try bending the tabs first.
should only require hand pressure to install.
can't say I have ever seen a later model gw with grommets there.
Old 04-21-2019, 06:27 PM
As they are I can slip them into the hole but they don't set down flush as I think they should. They are probably 1/8" above the top of the door. I wasn't thinking of removing the woodgrain material from the door just trying to access the grommet tabs from below to hopefully bend the tabs enough to hold the grommets down in place.
Old 04-22-2019, 02:54 PM
RamJetFSJ RamJetFSJ is offline
yes, you have to remove the door panel and push the tabs back from inside the door. Even then its hard to get them nice and tight.
Ben Haines
1980 Wagoneer - GM Perf. Ram Jet 350 crate motor, built 700R4, NP208, 4" lift, 33x10.5 tires.
Old 04-23-2019, 08:28 AM
Thanks RamJet that's the info I needed. I'm assuming that the RamJet name refers to a SBC in your Jeep?
'91 GW
2000 TJ
'41 Ford Real honest to gosh woodie
Old 04-23-2019, 12:59 PM
yep.
Ben Haines
Another A/C Question: York or Sanden The PIG Smith General FSJ Tech 27 07-03-2018 04:29 PM
Axle Question Jjkage84 General FSJ Tech 4 05-12-2014 11:22 PM
1 PS question, 1 eletrical question SamW General FSJ Tech 2 01-15-2011 12:31 PM
Quick 85 Grand Wagoneer Question WagoneerMan General FSJ Tech 3 01-31-2010 11:06 PM
