Old 02-10-2019, 07:51 AM
JeepsAndGuns's Avatar
JeepsAndGuns JeepsAndGuns is online now
Originally Posted by SC/397
No. Even the most expensive timing gear needs re-worked to make right. Every now and then the oil passage does line up with the oil feed hole in the cam but it is rare.
That's sad. I guess things have changed since I built my engine somewhere around 2004-2005. If I remember correctly, I used a rollmaster billet timing set and did not have to do anything to it. Been running great for around 15 years.
Old 02-13-2019, 05:22 AM
cma's Avatar
cma cma is offline
Rik!
Again great work!
One Engine more from you in Europe! (By the way, my one is running like champ!)
Markus!
Picture story:
Old 02-14-2019, 11:22 AM
SC/397's Avatar
SC/397 SC/397 is offline
Thank You Markus!
Glad to hear that your Jeep is running well my Friend.
Old 02-18-2019, 02:43 PM
SC/397's Avatar
15 years is a long time in the after market world. Even the Rollmaster product has changed companies and has changed in design. Again, you have to check them all.
http://theamcforum.com/forum/rollmas...945_page1.html
Old 02-18-2019, 02:49 PM
SC/397's Avatar
I just have to mock up the York Compressor Kit and she is ready to crate!
I like the look of the cast aluminum powder coated intake and rocker arm covers. Has a serious look to it.
IMG_1317 by Rick Jones, on Flickr
Old 02-18-2019, 08:45 PM
DarkMonohue's Avatar
Shakes hands with danger
Pretty. But I sure wish you'd stop giving me expensive idears.
Old 02-25-2019, 01:56 PM
Probesport's Avatar
Probesport Probesport is offline
Very nice clean work. I always appreciate simplicity, even when it's quite complicated.
Ken S.
Jeep toy: 1988 Jeep Grand Wagoneer
Megasquirt EFI
: Heated Seats : Blower fix : Driving light brackets : Shorty headers : Coil Packs : Electric Fans
Prior Jeeps: 1997 Jeep Wrangler TJ, 1994 Jeep Grand Cherokee Limited
Other toys: 1930 Model A (Hotrod), 1997 Ford Probe Turbo, 2000 Jaguar XJ8, 2005 VW Touareg
Old 05-09-2019, 04:53 AM
marsupilami marsupilami is offline
Hi Rick,
Great job! I was already fascinated by your first "budget" build.
Now I am getting closer to my own build. I could get a core 360 with the right heads to use the 343 pistons.
Some questions I have, just to know what I need to order:
- Have you used new bolts on the rebuild or did you re-use the old ones?
- Same with the valve springs. New or used dones?
- what is the difference between the cam in this build compared to your preferred 268H? This one has better torque at lower RPM, but less HP at the high end?
I am not looking to build a race monster, I just want the engine to perform according to its possibilities.
Other parts I will be using as I have them on my engine:
-Edelbrock Performer intake
-Holley 4 barrel 600CFM
-IMPCO 300 Propane system
-Standard headers, but Smog "humps" are cleaned
-2,5" dual exhaust
-MSD 8523 Ignition
Thanks!
Robin
Old 05-09-2019, 08:31 AM
SC/397's Avatar
I use the old stock main bearing cap screws and head bolts after inspecting and cleaning. I replace all of the rest of the bolts with new grade 8 or stainless. - With the exception of the stud/bolt that the power steering pump bracket mounts to.
Most of the time I replace the valve springs to match up with the cam. I might use the original ones on a stocker if they look good and check ok on a spring tester.
Most of the time it is personal preference. According to the specifications the 268H is geared toward more mid range but I have found it to work well at the entire rpm range. In this build, the cam came as part of the kit so there was no other option. It is the same as the Edelbrock Performer cam. The Performer cam sounds like a stock cam with no lope at all. The 268H has a nice little lopedy lope at idle. The is my little cheat sheet for cams.
AMCcamList1 by Rick Jones, on Flickr
Old 05-21-2019, 02:32 PM
gophman's Avatar
gophman gophman is offline
Do you have an approximate hp/TQ figure for this style build?
Old 05-21-2019, 03:50 PM
SC/397's Avatar
It is very similar to the first one in this Dyno Test thread. I would put it close to 300 hp and 370 #/ft of torque.
http://rebsamcandjeep.proboards.com/...no-time?page=1
Old 06-24-2019, 03:36 PM
SC/397's Avatar
Nice to have some kind words and nice to see the finished product!
Hi Rick,
Great Engine!
Since 2 weeks the AMC 360 is installed.
And every time I'm starting the engine I've a big smile in my face.
Thank you for building such a great engine. Attached some pictures.
Regards, Ron Schelling
IMG_20190606_081855 by Rick Jones, on Flickr
IMG_20190606_081720 by Rick Jones, on Flickr
IMG_20190607_192520 by Rick Jones, on Flickr
Old 06-24-2019, 05:36 PM
needs a fan shroud!
Time to Build - 1969 Wagoneer Arizona EnigmaticEngineer Off-Road FSJ Tech 26 02-13-2010 09:02 AM
AMC360 rebuild prices? jeepdreamer General FSJ Tech 1 10-21-2009 07:23 AM
rebuild or remanufactured? JPSwapMohn General FSJ Tech 34 02-24-2007 03:44 PM
Engine rebuild / replace advice... ?? -long SFFSJ General FSJ Tech 2 03-06-2003 07:16 PM
