Old 05-18-2010, 06:42 AM
hrst390 hrst390 is offline
NEED AN EDUCATION ON A 1970 J4000
I'm going to be picking up a 1970 j4000 this week...I had a quick 2 minutes to look at it yesterday and noticed 5 lug ford wheels on it..is it a 3/4 ton with 5 lugs?
It has the 350 buick engine with 4-speed...what transfer case will it have and what rearend?
body is good but has the glass broken out so i will probably part it out as i need parts for a j-20...
anyone need a buick engine?
Old 05-18-2010, 06:49 AM
J4000 only specifies the wheelbase, not the GVWR. If you have the VIN, that will tell you something about the truck. There is a VIN lookup in the Tech Library, one for each year.
5-lug could be Dana 44s front and rear, or 44 front 60-2 rear for the 'middle' GVWRs. They all have Dana 20s.
Old 05-18-2010, 06:55 AM
Re the engine, advertise on the CJ and Jeepster forums. The 350 is a great replacement for the 225 V6, especially in a Jeepster with the TH400.
Old 05-18-2010, 07:46 AM
Headhoncho's Avatar
Front will be a dana 44, rear could be the same as front (check diff cover)or most likely it's a dana 53 or a dana 60 (not sure when last year for 53 was). It will have the dana 20 TC and the Buick engine is well worth keeping.
JR
1966 mustang fastback
'07 Dodge Charger 3.5
Old 05-18-2010, 08:13 AM
When i get it home I'll post some pics and decide what I'm keeping..thanks for the info..
I have no interest in the buick engine...I'm sure the buick is a fine engine but have too many AMC engines to use...
now the next question..
Is the bell a std BOP pattern or does it use an adapter like the v-6? will an AMC v-8 bell work on that trans?
I can redrill a bell for the trans pattern but will the depth of an AMC bell work with that trans?
Old 05-18-2010, 08:15 AM
TK421's Avatar
TK421 TK421 is offline
I would like first dibs on ac equipment, power steering equipment, four bbl intake if it has one and all the necessary brackets. Let me know...I love my Buick 350!
1970 J4600, 350
1974 J10, AMC 258
Carolina FSJ website: (Flintster)
Old 05-18-2010, 08:26 AM
2bbl...don't think it had air...let you know..I may go get it wed. if it dries up enough...
Old 05-18-2010, 08:28 AM
I do have an early 455 cast iron 4bbl though i would sell...and i think p.s. pump and brackets my neigbor brought over to me...came off his car...
Old 05-18-2010, 08:29 AM
Headhoncho's Avatar
The bell will be a BOP pattern with no adapter unlike the TH400. Not sure if there is an AMC pattern bell that will work with that trans depth wise.
JR
Old 05-18-2010, 11:42 AM
JR
The stock Th400 will have the Buick "nailhead" bolt pattern, not BOP. There will be a factory adapter used to mate it to the motor. All th400's prior to 74 used that bolt pattern and an adaptor regaless if behind an AMC or Buick motor.
Old 05-18-2010, 11:45 AM
The 5th digit of the VIN gives you the GVWR.W= 5000lb, X=6000. Y=7000, Z=8000 or 8600 if DRW. If W rear axle will be D44, X and Y use a semi-floater D60-2, X uses conventional D60 full floater.
Old 05-18-2010, 12:39 PM
twisted frame twisted frame is offline
If the interior door panels are black and in good shape then I'm interested.
Looks like you're covered with all the info posted above. All I was going to add was that my 60-2 rear has "60-2" cast into the top of the diff housing.
Mike
1973 J4000, 360 2bbl, T18, Model 20,
44, 60-2, 32x11.5x15" on 15x8" CJ wagon wheels.
Now in black primer.
Old 05-18-2010, 12:41 PM
Originally Posted by joe
The 5th digit of the VIN gives you the GVWR.W= 5000lb, X=6000. Y=7000, Z=8000 or 8600 if DRW. If W rear axle will be D44, X and Y use a semi-floater D60-2, Z uses conventional D60 full floater.
Fixed it for ya'
Old 05-18-2010, 12:48 PM
...Not sure if there is an AMC pattern bell that will work with that trans depth wise.
Yes, the transmission will have a long stickout and may have an adapter (spacer) between the bell and the transmission. Some of these have an odd bellhousing with the spacer and bellhousing cast together, but I'm not sure which app has what. But all the V8 apps will have something like a 12" stickout for the input shaft... and I presume that the different V8s have different stickouts. So you may have trouble making that T-18 work with an AMC pattern bell.
One possibility is to replace the input shaft with the short Ford shaft, then the input will have the right depth for the T-150 or T-176 AMC pattern bell.
Old 05-18-2010, 01:20 PM
I have a bell with an adapeter between the bell and tranny from an 80's wagoneer that had a 360..then i have std AMC bells in both depths..I am a manual tranny guy since i race with a jerico in my drag car so I thought I might use this tranny in one of my other automatic trucks..
I have to get the thing home 1st..lol
Old 05-20-2010, 12:01 PM
Thanks for the help guys..I have what i need off it and here the rest goes...
http://www.ifsja.org/forums/vb/showthread.php?t=122271
Old 05-21-2010, 12:04 PM
why did you pull my for sale thread??
1970 j4000 problems. please help me!!! hooksetter General FSJ Discussion 0 04-13-2010 06:42 PM
Please Help 1970 J4000 hooksetter General FSJ Tech 7 02-17-2010 11:13 AM
71 J4000 serial # BuickPower General FSJ Discussion 3 12-13-2009 06:45 AM
Who knows about 1970 J4000 4x4's? Rusty General FSJ Tech 3 09-22-2001 09:34 AM
