I don't know if there are any Megasquirt gurus around here any more but it's certainly worth a shot.
I've got a MS2 v3.0 board set up for fuel-only, coil-negative operation. The ignition system works, I've run XG1 thru the header, I've tried the software noise filtering.
I still get a loss of sync and a reading of 18,000 RPM, 300 rpm, gibberish, etc when it starts to run. Fuel then shuts off.
I was running PWM, then switched to 3.3 ohm 25 watt resistors in line with injectors, no change.
It's a 1975 Prestolite equipped 401.
I'm thinking, though I'd hate to, maybe I should set up the MS2 for hall effect and run coil control after all? Or go for broke, put a trigger wheel on there, and run waste spark?
Really wanted to keep it simple & cheap at first, see if I even like driving the car before it got *too* involved...
