Old 09-01-2000, 02:36 PM
Langdon Langdon is offline
Question
Greetings,
I just bought my FSJ, and will be using you guys extensively as I try to get it back into good enough shape that my girlfriend will be seen in it. Anyway, first things first:
Are Wag/G.Wag and Chero rear windows the same? How 'bout tailgates, for that matter?
Thanks
Old 09-01-2000, 02:50 PM
Ralph's Avatar
Ralph Ralph is offline
Third Member
Wink
They're the same, save for a few cosmetic differences, and whether you have an electric or manual setup.
What problems are you having with yours?
Old 09-01-2000, 02:52 PM
Narnian Narnian is offline
Thumbs up
Just spray some air freshener in there and she'll love it!
Old 09-01-2000, 03:58 PM
Wink
Generally speaking they're the same but somewhere in the 80's they went to a thinner glass so I think that also affected the channel the window sits it when it's up and prolly in the tailgate as well but not sure.
-joe
Old 09-01-2000, 04:07 PM
Unhappy
Problem is, it's not there! Having defrost would be nice, too. I ask because G.Wags are much more plentiful at the junkyard.
Langdon
'79 Cherokee S
360 2bbl, TH400, Q-Trac
Old 09-01-2000, 04:37 PM
ClarkGriswald's Avatar
ClarkGriswald ClarkGriswald is offline
Wink
Jeese.. its like women against FSJ's out there. The FSJ's are like that abnoxious drunk buddy that never seems to go away and annoys the he** out of your companion. Do any of you feel like you are cheating on your partner with your FSJ? he he he he.. I hope not..
88 Grand Wagoneer
D44's front\rear
Warn 20990 Lockouts
AMC 360
TF 727
NP 229 (Funky)
Custom Hacking Via S.P.A. (Standard Polish Archetecture)
Old 09-01-2000, 07:52 PM
Ralph's Avatar
Third Member
Wink
Langdon, I wouldn't advise that you get a tailgate glass from a salvage yard, especially if you want a defroster that works. New glass with defrost element can be had for less than $200 (I have a source in Columbus, OH, if you can come here to get it).
You'll then need a new channel for the bottom of the glass, which will cost you around $30 from a dealer -- again, don't test your luck getting one of these from a salvage vehicle, because they rust and fall apart.
Old 09-02-2000, 07:07 AM
Rick
Posts: n/a
Lightbulb
since were on the subject, did any models use clips or anything else to hold the glass in.
87 Grand wagoneer (stock, for now)
85 Grand Wagoneer LTD (soon to be parts beast)
NP 208
Warn Locking Hubs
15x8 Black RockCrawlers
And still piling up parts
Old 09-02-2000, 09:32 AM
Ralph's Avatar
Third Member
Wink
They have a retainer clip at each regulator arm intended to hold the pin in the channel slot. Also, that pin should turn freely, or else one side of it will get worn flat.
The pins are machined in place. I removed both of mine and replaced them with my own mix of nuts, bolts, springs, and finishing washers. About two months now and it seems to be holding up fine.
Old 09-02-2000, 11:59 PM
scotty's Avatar
scotty scotty is offline
Wink
i have rear glass as well,i cant remember if it has defrost or not,but youre welcome to it(no roof makes rear window irrelavent) im currently using my tailgate for spare parts storage. im on occasion as far east as wheeling,wv if you dont want to come to dayton...
scott
85 grand wagoneer
258 with motorcraft 2bbl/904/twin stick dana 300/dana 44/welded amc 20
38x15.5 gumbo mudders
snorkel/dual batteries/onboard air/"custom" convertable
3 inch body lift/mostly stock suspension/"modified" fender openings
custom front/rear bumpers and brushgaurd
possible small block chevy "test" swap in near future
Old 09-03-2000, 10:08 AM
Exclamation
Scotty,
Sure, I'd take it if i could pick it up in Wheeling sometime soon (say in the next 2 weeks?) Otherwise I'll have to break down and buy a replacement. Lemme know here or by direct email.
Thanks
Langdon
'79 Cherokee S
Old 09-04-2000, 04:00 AM
BobBarry
Posts: n/a
Wink
<BLOCKQUOTE>quote:</font><HR>Originally posted by Langdon:
<HR></BLOCKQUOTE>
The tailgate windows will interchange, as will the tailgates, except for one point: the latches changed some time between 1979 and 1982. You could fit the earlier latches to a later door by redrilling a few holes, but it's a kludge and it looks like it.
Bob Barry<UL TYPE=SQUARE>* '78 Cherokee 4-door
* '88 Grand Wagoneer[/list]http://studentweb.providence.edu/~rbarry/wheels/
