Hey guys!
Started on my Rhino conversion today. Part of putting the old Gladiator grill on required me to move the tranny cooler. My AC system is busted, so I decided to remove everything, pump, condenser, cooler, dryer, hoses...
This turned out to be very challenging! After several hours of messing with the pump I finally got it out. Got the new fan belts installed and noticed there was a huge pool of green coolent on the ground. Some where in the process I caused a leak on the water pump. Also discovered that some of the bolt holes started leaking motor oil. Plugged them up the best I could with shorter bolts I had in a scrap coffee can. Did relocate the tranny cooler and got the grill bolted in.
Closed her up for the day and admired my handy work. When I fired up the jeep I noticed a horrible swishing sound. Opened the hood again and its coming from the Power steering pump!!! How in all of this did I mess up the power steering pump?!?!? It was fine when I parked it. Drove it back to the house anyway since I was out of time and needed to come in for dinner and every time I turned you could hear some grinding.
I got a spare off a junker that some guy was parting out, but I'm not sure if it works. Ugh. Can never win with these FSJ's can you?!?!!
I will post pictures of the Rhino conversion once I replace the square headlights with the round and bolt on the pie pans. Gota do some welding for that.
Sean Kelly
Sean Kelly
