For those with TBI and the AMC 360, what is your ignition timing set at (base and advance if applicable)?
I am using a non-ecm HEI with a GM TBI and just looking for ideas of what works the best for everyone. Right now, I have the engine set at 6 degrees advanced and the stock mechanical advance of about 20 degree. I unhooked the vac advance because it advanced it too much in combination with everything else. It seems to do ok, but stills needs some adjustment for better throttle response.
