Hey everyone. Been a while since I've posted here. Hope everyone is doing well.
So, here's what's going on. Since I currently own 3 vehicles, I've decided to lighten the load a little bit, so to speak. There's really not a whole lot of need for 4WD around the SF Bay Area, so I want to get my Jeep fixed up and give it to my mom. Her and her b/f only have one reliable 4WD vehicle between them and the winters in ID aren't the same as the winters in the Bay.
So, here's the starting point:
Rebuilt 360, TH400, QT and rear end
Stock Dana 44s with a Tru-Trac in the rear
Howell EFI
MSD Offroad 6 ignition box, Pro-billet distributor and High-vibration Blaster coil
I'm sure there's some more I'm forgetting, but that's all I can recall right now. So, first thing's first...fuel supply. I'm using the stock tank right now with the supplied pump and filter from Howell. I had the kit installed when I had the motor rebuilt and I believe the lines aren't the factory ones, rather rubber lines from tank to TB. Since its been sitting for a while, I know the fuel in the tank is probably shot. So, this is the list of things I want to tackle for this part of the project:
New fuel tank
New fuel pump
New fuel filter
New fuel lines?
Add valve on fuel supply line to check fuel pressure
Also, I've noticed that, under hard acceleration, the TB starts to starve for fuel when the tank is under about 50% or so since I converted it. I've been thinking about both Aero Tanks and BJ's Offroad for a baffled fuel tank to fix this, but not 100% sure. What do you guys think? Also, in-tank or external pump? I'm partial to in-tank myself, but I don't want this to be an overly-complicated setup. Any and all help/suggestions are appreciated. Thanks everyone.
Howell EFI
New fuel tank
New fuel pump
New fuel filter
New fuel lines?
