parking brake switch/dome light question
  • Steelhead
    • Feb 11, 2002
    • 305
    I rarely use my parking brake. Last night after driving I stepped on the parking brake and then released it. After releasing it, my dome light stayed on. I finally found the culprit was a switch on the parking brake near the floor. It seems the switch is activated when the brake is pressed. After fiddling with it, the dome light went out, though I couldn't recreate the problem. Anyone know what that switch on the parking brake is for?
    I'll take a picture if needed.
    ---'76 Chief, 401 rebuild, custom springs - 5" rear, 4" front, 32s, manual front hubs, 44 gal. tank (w/aux), Carter 9635, HEI, Edelbrock manifold, Crane cam, dual side exhaust---
  • mrtazwrench
    • Nov 10, 2001
    • 3987
    the switch is for the brake warning switch on the dash, as far as the dome light issue, if you have the under dash lights that come on with the dame lamp i would look for the wire to the driver's side one pinched in the e-brake lever.
    Chad
    "Let's see that Red Blue Green **** sucker build one of these without duct taping it together!"
    88Wag
    87J20 Member, FSJ Prissy Restoration Association
    83Cherokee WT
    82J20
    Parts vehicles: 1.5 Wags, 3.5 J20's, 1 J10 1 J300
    • Steelhead
      • Feb 11, 2002
      • 305
      hmmm...no pinched wire that I could find, but somethings got be crossed 'cause that switch somehow toggled the dome and under-dash lights. Its certainly never lit a warning light on my dash. I'd pay big bucks to have an expert clean up the wiring mess under there. It looks like spaghetti. thanks...I'll keep looking.
      • J4GRAND
        J4000 Restoration Specialist
        • Apr 09, 2000
        • 5937
        It sounds like someone at one time hooked your under dash courtesy lights into your parking brake switch. Does your dome light and cortesy lights come on when opening the door? If not, I bet that's what happened.
        Patrick V.
        MEMBER #14
        78 Cherokee Chief WT "Old Blue" 360 V8 4V TH400 QT RIP
