02-25-2021, 08:09 PM
Just a heads-up - fan/shroud possibility
Took a chance on measurements and this fits our radiators with 1/4" clearance. Almost like it was made for them. Not going into mechanical vs. electric discussions, just a FYI for those who want a way to pull a lot of air and not willing to pay $175 for the pathetic factory shroud.
Brackets need to be cut off (took less than one min for all 4 with a cut-off wheel) and four holes drilled for an install using the typical fan mount-through-radiator kits ( https://www.amazon.com/Upgr8-Universal-Through-Radiator-Plastic/dp/B07L542CJH/ref=sr_1_3?dchild=1&keywords=fan+mount+kit&qid=161 4305096&s=automotive&sr=1-3). Otherwise, this is an almost 100% coverage on FSJ rads (honestly, way more coverage for shroud than the factory).
This fan/shroud setup: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
PS. The fans are cheap Chinese, but same size as any other of the better aftermarket 12" fans out there (Mishimoto, SPAL, Flex-A-Lite, etc.)
02-27-2021, 07:51 PM
Bump
This is for later reference.
1982 Cherokee
258 cid/T-5 $15 Sunpro Voltmeter gauge
replacement; Quadratec Trailmax Thermal Pro
Seats! 4 inch SKYJACKER suspension lift, 33X12.5 in
BFG Mud Terrain Tires on 15X10 in ProComp Rims.
New BJ's chrome-moly rear axle shafts, 3.73:1 diffs and ARB Air Locker!
02-27-2021, 07:53 PM
whats the amp draw?
steve
Abort? Retry? Ignore? >
02-28-2021, 10:17 AM
Just throwing it out there...
I upgraded my 94 Caprice to use stock dual electric fan setup and NO shroud is used.
Pushed that car HARD on many occassions and never had any issues.
I would think that all that blocked area could drastically reduce airflow under some conditions?
02-28-2021, 11:40 AM
Originally Posted by Tripwire
whats the amp draw?
steve
"Maximum Fan RPM/ Amp Draw :2,250 rpm / 12.70 amps"
That's stated. Actual I won't know till I get it hooked up and going and toss an ammeter in line.
"Jeepjake" on this site 20-years ago, did the first Ouray Invasion (stuck on Imogene pass, wrote a story about it), then subsequent Uninvasion the next year. Been working on Jeeps 50-years, have had a Jeep of one rendition or another all my adult life.
02-28-2021, 11:46 AM
Prob w/these vehicles is tight/hot engine compartment and reversion if no shroud.
