Old 10-01-2002, 01:44 PM
tomd's Avatar
tomd tomd is offline
OK, i found a wrecked 73 with a possibly usable body (not front clip though) and was wondering if it isn't tweaked, would it bolt onto my 74 chassis?
[ October 01, 2002, 07:50 PM: Message edited by: 74 Wag ]
71 J-4000 on a 76 Cherokee chassis with homemade flatbed
360/Th400/PT QT/3.07 D44s
Old 10-01-2002, 01:57 PM
PAJEEPER PAJEEPER is offline
There is differences in the frames but I don't see why it cant be done. You'll have alot of parts there to work with. It will work even better if you have a welder.
Old 10-01-2002, 02:01 PM
tomd's Avatar
what kind of differences in the frames?
the 73 is 360/TH400/QT/27/44
the 74 is 401/TH400/QT/44s
both have post mount rear springs, and fronts i don't really know if they are the same or not.
the 74 i am told has 14 body mounts, how many on the 73?
Old 10-01-2002, 02:06 PM
It should mainly be in the body mounts. You may have more or less and the postion may be a little diffrent. Nothing you cant work out easily though. Tough part would be transfering the body over. It will be very heavy you can remove everything you can unbolt from it and lighten it up.
