Can someone photoshop this onto the center of a 1987 GW Dash?
Photoshop Guys
Photoshop Guys
"You fancy people with your shoes."
87 Grand Wagoneer
2009 GMC 5.3L Vortec
Sterling 10.25 Rear
8 Lug J10 Front
TSM Mfg Rear Disk Brake Conversion
33 Gallon Rear Poly Tank
69 J-3000 Pickup
Plans:
2.8 Cummins Diesel Repower
6L90
Atlas Transfer Case
82 J-10 Pickup 258
Leave it as-is except to fix all the issues.Tags: None
Trying to find good dash image but so far no luck.
I want to replace the entire center of the dash with this slightly outset (2 inches maybe). So remove:- A/C Switches
- Radio
- Ash Tray
- Glove Box
87 Grand Wagoneer
Sterling 10.25 Rear
8 Lug J10 Front
69 J-3000 Pickup
Plans:
6L90
Atlas Transfer Case
82 J-10 Pickup 258
Best I could find on the dash picture. Also note the AC ducts on the bottom of the dash will also be gone.
Thanks!!"You fancy people with your shoes."
87 Grand Wagoneer
Sterling 10.25 Rear
8 Lug J10 Front
69 J-3000 Pickup
Plans:
6L90
Atlas Transfer Case
82 J-10 Pickup 258
Also, the two pictures are definitely taken at different distances. The center piece is a corvette dash so it should be smaller."You fancy people with your shoes."
87 Grand Wagoneer
Sterling 10.25 Rear
8 Lug J10 Front
69 J-3000 Pickup
Plans:
6L90
Atlas Transfer Case
82 J-10 Pickup 258
that's not bad. i'm like you not too sure about the size. maybe I can get dimensions of the actual dash insert."You fancy people with your shoes."
87 Grand Wagoneer
Sterling 10.25 Rear
8 Lug J10 Front
69 J-3000 Pickup
Plans:
6L90
Atlas Transfer Case
82 J-10 Pickup 258
actually a good guage might be the A/C switches and the left upper hole just below the vents. They are both GM switches I believe."You fancy people with your shoes."
87 Grand Wagoneer
Sterling 10.25 Rear
8 Lug J10 Front
69 J-3000 Pickup
Plans:
6L90
Atlas Transfer Case
82 J-10 Pickup 258
Hey, I've got it...
The bottom hole on the dash insert is a 1-DIN radio mount same as the radio pictured in the dash. if you make that bottom hole the same size as the radio, it should be the correct size in relation to the dash."You fancy people with your shoes."
87 Grand Wagoneer
Sterling 10.25 Rear
8 Lug J10 Front
69 J-3000 Pickup
Plans:
6L90
Atlas Transfer Case
82 J-10 Pickup 258
I tried matching the 1 DIN radio with the bezel the size looks right for the corvette but it is way too small for the Jeep.
Thanks anyway...
Back to the drawing board..."You fancy people with your shoes."
87 Grand Wagoneer
Sterling 10.25 Rear
8 Lug J10 Front
69 J-3000 Pickup
Plans:
6L90
Atlas Transfer Case
82 J-10 Pickup 258
Originally posted by skeletornot to be a jerk here, but on the photoshop pic it looks like optimus prime is inside of your dash...
Actually, that center dash piece is from a 1989 corvette."You fancy people with your shoes."
87 Grand Wagoneer
Sterling 10.25 Rear
8 Lug J10 Front
69 J-3000 Pickup
Plans:
6L90
Atlas Transfer Case
82 J-10 Pickup 258
