What size tires will be the best if I put on a Bj's 6'' Lift on my 1982 jeep cherokee wide track.
1982 Jeep Cherokee Wide Track
35s unless you start trimmingYep, I know my PM box is full. Email me instead.
Yes, 35"s are perfect.1977 J-20, 4bbl AMC 360/t-18,33"s.
1976 CJ-5, Healthy AMC 360/t-18, 6" lift, 35"s.
1972 Javelin SST, mild AMC 360. Under cunstruction.
AMC ya!!
Alfano Performance
Kenosha, WI 53142
The stock 8" wide or maybe a 10" wide with a 12.50" wide tire should give you no problems if taken off road with the 6" lift.1977 J-20, 4bbl AMC 360/t-18,33"s.
AMC ya!!
Alfano Performance
Kenosha, WI 53142
Even with the wider wheels, you'll still have rubbing on the flares when fully flexed. Even with a 6" lift.
If you can find some 34" tires you should be fine.Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
?Freedom is never more than one generation away from extinction? by Ronald Reagan.
