  #3501
Old 11-17-2019, 01:39 PM
bufurd's Avatar
bufurd bufurd is offline
Continue to fight the battle... 3 cans of Fluid Film spraying every nook and cranny underneath,, my way of winterizing.
Current fleet
07 JK Wife bought new...
Old 11-24-2019, 11:20 PM
letank's Avatar
letank letank is offline
bad spark plug
I had a misfiring, then low power. While checking which spark plug, I got the 50Kv jolt... yeaaah, found the issue of a bad spark plug wire... swap wire, check spark plug, it was clean and tan... restart ... get another jolt.... aaaaack, so I put a new spark plug... and yes it is now running fine.
Weird, the spark plug has no cracked insulator... no excessive dirt on the porcelain... only 6 years and 20K miles on that champion 404.
Michel
Old 11-25-2019, 05:22 AM
hudwagon hudwagon is offline
Smile
new rotors, bearings, calipers & pads , no more pull when braking. next is cargo area carperting. Then i think i may tackle the rear wiper Durango mod if i get brave enough
Old 05-29-2020, 02:14 PM
jeepgirl's Avatar
jeepgirl jeepgirl is offline
Rotting cardboard replacement!!
Finally replaced the rotting cardboard backing of the Jeep door cards (40+ yrs old) with ABS plastic. Took a couple days and turned out pretty good.. 👍
"Silly boys.. Jeeps are for girls!"
1978 Cherokee Chief "Ivy"
Old 05-30-2020, 10:44 AM
Brynjminjones's Avatar
Did you re-use the vinyl covering from the originals? Interested to see how it turned out!
1991 Grand Wagoneer - Hunter Green
1998 Cherokee (XJ) 4.0
1997 Grand Cherokee (ZJ) 4.0
1974 Ford F100 390
Old 05-30-2020, 12:39 PM
Mars's Avatar
Mars Mars is offline
I greased the hood latches to stop the constant and maddening squeaking on every single bump..
Wannabe Fabricator
Grumpy on a good day.
Old 05-30-2020, 01:24 PM
jsinajeep's Avatar
I just wish it was only the hood latch squeaking on mine. LOL
Old 05-30-2020, 01:41 PM
I hear that!
Last weekend we turned wrenches for 3 days to get Krista's waggy out of the back yard from a 2 year nap. At the time she was parked I started a few things that I didn't get back to for a while. The bucket seat brackets were cleaned and painted and I attached 98 Mustang seats to them. A SS battery tray replaced the factory tray. Then I got into replacing the 20+ year old Hedman headers. Last weekend the headers were installed and the new collectors were welded to the twice pipes. New HEI cap, rotor, plugs and wires installed. Heater hoses replaced. Oil changed and oil pump primed. Discovered leak at the oil pressure sender. The brass nipple broke off inside. It was drilled out and the hole welded shut until a permanent solution is worked out. New belts. 5 gallons of gas and fired her up. The sound of the twice pipes was exciting! Drove her to town and gave her a bath. On Tuesday, Krista drove her to work.
Our minds aren't made up on the seats yet. Climbing over the side bolsters are a bit of a PITA.
There they go to work!
Old 05-30-2020, 07:56 PM
MadMax78's Avatar
MadMax78 MadMax78 is offline
Axle rebuilt finally
Finally got the rear axle rebuilt. So ready to get it back on the road. Fuel injection and new exhaust is next. So much to do but so little time.
MadMax78
78 Cherokee Chief, Wide Track, 360, TH400, Quadra Trac, SOA, 35" BFG KM2, Edelbrock Carb & Intake
Old 05-30-2020, 08:07 PM
Mars's Avatar
Well I replaced the exhaust a couple weeks back so now I can hear myself think and the squeaky hood.
Wannabe Fabricator
Old 06-02-2020, 05:38 PM
Flint, how well did those seats bolt up? Do you think they'd fold forward enough to gain access to the back seat of a Cherokee?
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 06-03-2020, 07:11 AM
The seats fit on the stock brackets pretty well. The 2 rear mount holes lined right up. New holes had to be drilled in the front about 1.5" towards the rear from the stock Mustang mount holes. The backs felt low to me so I put 3/4" spacers between seat and bracket.
On a good day, I would probably cripple myself trying to get in a 2 door Cherokee. Skinny folk can probably do it OK with these seats. The door post is just outside view on the left.
Old 06-03-2020, 11:24 PM
That's perfect! Thanks, Flint! I had a '76 Jimmy a few years ago with Fox Body Mustang seats in it. I liked them quite a bit. Those seats look like they'll work just fine, too. Very nice!
-Jonny B.
