I took my torque converter inspection cover
off last night and found that the bolts that
hold the flex plate to the converter have
been hitting the 1/16" plate that goes between the trans and the engine. I had been hearing a noise on hard acceleration that
has been getting gradually worse over the last year. It looks like there is about 3/16"
clearance on all four bolts, but somehow the
bolts are hitting this plate under acceleration. The top of the bolt heads are worn off, and there is a spray of metal shavings on the flex plate next to the bolts.
The plate checked flat with a straight edge. Is the flex plate supposed to flex this much?
