GM TBI swap - I'm stumped
  • elskeptico
    • Sep 03, 2003
    • 821
    Looking for a little help.
    - AMC 360 (healthy pre-swap)
    - GM TBI junk yard parts and some new/rebuilt
    - 1227747 ECU and TB from a 1991 Chevrolet Sport Van G20
    - Used the 8-pin ignition control module and existing ESC with knock sensor
    - Distributor is welded and disconnected from vacuum
    - Fuel pump is brand new MSD mounted outside tank
    - Coil is new Delco HEI
    - Separate relays for fuel pump and other stuff
    I spent much of the weekend reading through posts and double checking my wiring and assumptions, but I still can't get it started normally. I don't have a way of datalogging yet, sorry.
    I have spark and fuel. No error codes.
    MAIN ISSUE: the only way I can get it started is if I set the distributor WAY advanced (like about 50 degrees), and give it throttle while cranking. I got it started (real rough) and kept it running to warm it up enough that I could check the timing at idle, which showed about 10 deg. BTDC. I drove it around the block, actually drove okay (not great), got it back in the driveway and turned the key off but...it kept running I was out of time, so I just pulled the fuse on the TBI stuff and it shut off.
    I'm assuming the fact that I couldn't shut it off means my ignition switch is bad. Anything else that could cause that? I suppose a stuck relay could do it.
    My hunch is a bad ignition module, but it's getting spark, so...
    Things I've already checked/calibrated:
    - All typical voltage checks (coil, injectors, ALDL)
    - TPS sensor adjusted to about .58V at idle
    - Coil (resistance checks found online, checks out fine)
    - System is well-grounded to engine block
    [I have not "reset" the IAC because that requires a running engine and I just barely got it running]
    There
    1979 Cherokee Chief S, 360, TFI, Part-time conversion, rust
    If you go lookin' for rust, you'll find it.
  • babywag
    • Jun 08, 2005
    • 10287
    You may need a diode on the alternator wire to resolve the run-on with key off issue...had to do that on my 90GW.
    Try reversing the distributor pickup wires. They will cause big issues if reversed.
    Specifically, timing that is WAY outta whack.
    • elskeptico
      • Sep 03, 2003
      • 821
      Thanks, I'll look into the diode.
      I've already swapped the pickup wires, actually, didn't help. Previously had purple going to P and orange to N, and switched them after seeing one of your prior posts about doing it the other way.
      • babywag
        • Jun 08, 2005
        • 10287
        Distributor a tooth off? Or plug wires 1 position off?
        • babywag
          • Jun 08, 2005
          • 10287
          Also if this is a "new" made in China module YES it could be bad...
          many many instances of new aftermarket junk right out of the box.
          • elskeptico
            • Sep 03, 2003
            • 821
            Plug wires, no. Tooth off is possible. One thing I couldn't find was what's the "optimal" place to set the distributor in relation to TDC for this swap? Like I said, I had to rotate it very advanced to get it to start/run at all.
            The module I'm using was from the junk yard.
            • babywag
              • Jun 08, 2005
              • 10287
              I run them @ 0 degrees and let the computer do timing.
              Some folks for whatever reason cannot do 0 degrees.
              If not 0 degrees the .bin needs to match the initial timing and the timing table needs to be correct to account for the difference.
              What is the .bin BCC#?
              • elskeptico
                • Sep 03, 2003
                • 821
                I had set it at or close to 0 initially, but couldn't get it to do anything until advancing it significantly.
                BCC is ARJV (or maybe ARJU). The Bin finder on gearhead-efi.com doesn't give any results for this BCC.
                • babywag
                  • Jun 08, 2005
                  • 10287
                  ARJU sounds familiar CA-only .bin iirc
                  Have you checked for codes?
                  Do you have ability to read/burn or swap a diff chip?
                  • elskeptico
                    • Sep 03, 2003
                    • 821
                    I don't have any codes, even after getting it started rough and driving around for a bit.
                    I don't have any chip burning capabilities yet, and no other chips to try. I might try to get to picknpull tomorrow and see if I can find another ignition module to try. Thanks for the help.
                    • elskeptico
                      • Sep 03, 2003
                      • 821
                      For clarity, I followed this wiring diagram almost exactly:
                      And here's how I did the coil wiring:
                      Even though the coil gets 12V+ from the black connector, I assumed it also needed a source through the bigger wire in the gray connector.
                      • elskeptico
                        • Sep 03, 2003
                        • 821
                        Okay, I'm an idiot. The engine run-on issue was due to the way I wired the coil (wrong).
                        Does the coil only require the pink and white wires that come from the ignition module (pink gets 12+ from relay)?
                        • babywag
                          • Jun 08, 2005
                          • 10287
                          Small wires from coil pink/white go only to module.
                          Should NOT get power from elsewhere.
                          Only large gauge coil wire should get power in crank/run positions.
                          Here is a GM wiring diagram I simplified many years ago.
                          Promised this to someone else, figured might be useful to others as well? New link, google changed things again... https://drive.google.com/file/d/0B7yskeUx6UviVUp0SWdDX1owbkU/view?usp=sharing&resourcekey=0-5K3XwxBm4bAaAqq4Lz8LBA
                          • elskeptico
                            • Sep 03, 2003
                            • 821
                            http://www.ifsja.org/forums/vb/showthread.php?t=169223
                            Wow, thanks. I followed that diagram I found elsewhere (maybe binderplanet), guess it's wrong or I misunderstood it.
                            I have a relay for injectors, ECU, O2 sensor and ignition. Separate relay for fuel pump.
                            Should I have a third relay for ignition alone?
                            • babywag
                              • Jun 08, 2005
                              • 10287
                              Your choice...both mine only have/use 2 relays
