Originally posted by Carnuck
Whoa, thanks for the pics! It's too late for the axle. I woke up early and hauled it all to the scrap yard. I made enough to buy the matching rear axle outright.
I have two options for PS: the plate method you posted pics for; I pulled that set up off a 73 j4000 at the north side wrecking yard. The second option is the system the PO used on the white 64 I dragged home over the summer. He fabricated several plates that bolted to the driver's side frame rail. It was pretty clever.
My main concern is routing the steering shaft. It looks like the main shaft will hit the motor mount on the driver's side. I've been pouring over the Jeg's catalogue looking for the parts we'll need to safely by-pass that mount, but I am not sure what exactly I'll need, especially the diameter of the shafts. It might be time to invest in a more precise measuring tool like a micrometer or something.
Meanwhile, I did pull the rear axle from the Dodge, so now we have a matching set. The rear appears to have a limited slip of some type (as you helped point out on the Fsjnetwork site).
So now it's dismantle, inspect, repair/replace parts if needed, and get to work. Our goal is to have the front end and firewall stripped by Jan. 1st.
