Short history lesson on the truck. My Dad bought the truck when I was 4 years old. I'm almost 34 so I've had it a little while. He drove it until he passed away four years later. I learned to drive in the thing. It was originally a 360/T18 granny truck. It went through my brother's abusive driving habits and ended up with a new rear end and a new engine. He liked to play in the mud but never cleaned it out. You'll see in a little bit. After the rear spring hanger rotted, I couldn't weld yet, my Mom sold the truck while I was at the beach one year. Shortly after I returned, the truck was mysteriously back at my house and the guy that bought it had some of his money back. The bed was trashed though. So I decided to start taking it all apart, 7 years ago. I got it all apart then had to move houses, twice. So it got put on the back burner for a while. Once everything was settled, I knew I was moving to CA in January of this year. I had to get a move on it. Here's my spin on my Dad's old truck. Hope you enjoy it.
This starts with the cab off the truck and everything apart. Many years in VA with cold winters and snow, along with some mud and other stuff the floor had to be redone. I had already finished it in the pics.
[/IMG]
[/IMG]
SO once I got on the build wagon, I just jumped in with both feet. I pulled the front axle and springs. Here's the frame getting the front part prepped with the wire brush, primer and paint.
[/IMG]
The rear mid crossmember was a box and I wanted to make sure it was clean, so I cut it out and split it. Cleaned it up and put it all back together, and welded it back in.
[/IMG]
Once I knew that was done I needed to work on the rear of the frame. Remember the MUD and my brother's habit of not cleaning it. Well, the driver's side of the frame after that crossmember looked like swiss cheese. So I found a better section of frame from a truck in a salvage yard. Measured a lot of times and cut once, four separate times.
[/IMG]
[/IMG]
[/IMG]
Now it was ready for the axles and springs.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
