What's Up Group,
This cold is slowing my project down. Got my new rear springs on and tires are rubbing the springs on both sides. Here's the facts.
Dana 20 rear, stock 5 slot alum. rims 15x7's w/ 35/12.50/15
Front's are fine, turning radius slightly smaller but no rub, rear rub only.
Would you scrap the stock wheels and go with a 15x7 w/ less backspacing?
Would a 15x8 make the tire not stick out as much?
Would a set a spacers cure the problem and let me go with same wheels just that it would almost cost the same for newer wheels?
I'm bummed about the rubbing going on, I really like the old 5 slots look.
However, I've seen Stuka's rig and some others and I think those are black steel rock crawlers and I like the black look. Any suggestions or answers would be greatly appreciated.
I did a search on backspacing and read all the posts that came up. I'm still unsure. Thanks, guys, after this comes the POR 15 and to the body shop for paint. Pics will come when finished.
Thanks, Mario in Texas 1980 GW, 360, 727,FF44, RR D20, 3in.Spring Lift, 3 inch Body Lift, 35/12.50/15, Flowmaster, Warn
