I need some help (besides my mental stability); Got my truck back from the machine shop and it appears to be stuck in low range. I have been poking around the threads and could not find an answer to my question so here it goes.
The Jeep is on the 2wd setting on the dash switch and when I set it in park and engage 4wd you can here the vacuum line hissing behind the dash but it continues to hiss unless you switch it back to 2wd. However....if I move the transmission into neutral I can select between high and low range but it appears to do nothing. When I get it on the road it only wants to go about 30mph and nothing more...so I feel like it is stuck in low range.
I have been reading up and a lot of GW it seems suffer from vacuum line related issues to the transfer case and the 4wd system. My mechanic is trying to tell me that I need a new transfer case.
My question is could it be stuck in 4wd low due to a vacuum leak AND would it still allow me to engage / disengage 4wd high and low? Any help is appreciated.
Kris
Kris
