The purpose of this exercise is to learn a bit about how and/or why small carbs work on "big" engines (say, ours) and to what extent. Maybe a bit why a 450 CFM carb might be better in some cirucumstances than a 600 CFM. I need to dig up that chart that shows the break down of the MC2100 sizes to CFM because I'm sure a lot of people are still running their stock carbs. For the comparison of 450 to 600-ish CFM carbs here, we might as well say 4V carbs. Anyways, for the sake of this conversation let's pretend that our ignition system and timing are all perfect.
Of course gearing is a major consideration since it does have an effect on RPMs at a given speed. Since mine appears to be 4.10 geared and I'm running the stock T-18 manual, my comforable top speed is 60 mph @ 2,500 RPMs. Some day when I win the lottery maybe I'll swap in an NV4500 so I can go a little faster at a little lower RPM. I know the low gearing is going to hurt mileage but Ristow's example of a similar truck getting what I would consider impressive mileage w/ a small carb had me really thinking about this and wanting to learn.
Questions about different types of intakes are also a good point, I was assuming either stock 4V intake or the common Edelbrock Performer intake I think people run here (again, we're getting into 4V carbs). Or really for that matter the stock 2V intake w/ whichever MC2100 it's supposed to be running. Surely the split vs. single plane would make a difference in air velocity?
Regarding mechanical vs. vacuum secondaries, I'm not sure I agree w/ all the reports that indicate mechanicals are good for x while vacuums are better for x. I hear people preach it as well as hot rod/performance magazine articles. I just don't know. My Edelchock is mechanical and I love knowing exactly when the secondaries are going to open, from an economy point of view as well as performance. I have complete and udder (whoops) control over it but I'm more of a control freak when it comes to operating a vehicle anyways. I hate automatics/love manual transmissions, find myself preferring a manual choke, will run twin stick t-cases in all my rigs eventually, blah-blah-blah. In my mind the vacuum secondaries might start to open when I'm climbing a slight grade when I still have plenty of grunt left in the motor--I don't want or need secondaries opening all the time. Will they preform better under part-throttle operation (w/ a light spring)? Probably so, and I'm sure it's arguable that might be better than me having to put my foot way into it and get the motor wound up a bit before I get into the secondaries. Perhaps I could swap out the spring (in a Holley) so they'll come in real late, I guess. I believe the older Q-jet on my CJ-5 is also mechanical; just like my truck I can feel the tip-in in the pedal at around 50%-60% throttle (the Edelflood I think is 2/3-ish throttle), it suddenly gets a little firmer and you can hear the "vwoooom" under the hood. Point being is that it strikes me as a matter of taste which is better for your application. I'm happy and prefer my mechanical secondaries but admittedly haven't run a vacuum secondary carb yet. It's all theory and I might be a little weird (or dumb). The way things are going, I'm starting to snoop around on fleaBay for a Holley 450 CFM and learn about tuning Holleys.
Also good questions on exhaust. People typically indicate bigger pipes for high end horsepower or single smaller pipe for low end torque. Some folks say you need headers on an AMC to open them up and let them breath. I also recall seeing a lot of posts where people where sick of their headers and were wanting to swap back to stock exhaust manifolds. I never read into why. My truck has stock manifolds (no stove choke thing) w/ true dual pipes, I think maybe 2"? I think it's whatever size the "collector" of the stock manifold is. I'll have to look. Is it best for my setup and purpose? I dunno, I didn't put them there. I'd like to swap it to single larger pipe (2 1/2" for 360 c.i.d.? but there we go running numbers again) but that's way down the road. Maybe at least install an H-pipe to balance the two out. I understand that's supposed to be "better." Or whatever. I'll start another pointless exhaust thread some other time. Haha
