Jut cut a large flathead screwdriver and chuck into a drill, making sure it is centered into the oil pump gear drive slot.
'77 J-10 360 Rescue-Budget build
Originally posted by MikelJust a word of caution - I notice that your cam sprocket has six slots for oiling the chain. I had a similar timing set and I ended up wiping the cam gear because no oil was getting to it. I had all the oil passages lined up correctly.
As of today I'm waiting on parts to reinstall the fuel tank with. Sending unit checks out fine with ohm meter but the brass float had a pin hole so ordered new one those. Also o-ring, vent hose, filler hose, gas cap.
Meanwhile, got the front end back togeather. Starting to look like a truck again!
Mark
Stock '77 J10 Pioneer LWB
360 V8, 2bl (49 state)
T-18 4 speed
Dana 44's
31x10.50x15
I just looked back at your original link... Mine has a pretty large part # (S412T) stamped on the front that you can see in my above pic. Yours does not so it may not be a Cloyes. Whatever that may mean....
When I put the engine together I cut off the largest screw driver I had and used it to prime the pump and made sure I had oil to the lifters etc. But it was sketchy because it kept sliding out and I was afraid of breaking the flange off the pump gear stem. I guess it just wasn't large enough so I will look for something better.Mark
T-18 4 speed
Dana 44's
31x10.50x15
Sure look the same, down to the number
I'm not saying that you have the same problem, but in my case I did not get oil flow to the gear until I closed four of the six oiling slots in the sprocket. I really hope I'm wrong.Last edited by Mikel; 08-20-2015, 06:36 PM.1969 M715 6x6
1963 J300 Swivel frame
: 98 9er
'83 Honcho j10
'12 Liberty Ltd.. wifes
'19 Chaparral H2o Dlx sport 21
While waiting on the fuel tank to get cleaned I did pull the distributor and recheck gears for oiling as Mikel suggested. Didn't see any unusual wear. I tried turning the pump to check for oil flow but really couldn't see much at that angle. Maybe if I pulled the fuel pump off I could get a better view ??? I will keep my eye on it. I would hate to ruin a virgin 360 with 60k on it over a stupid fried distributor gear!
Ok..so I finally was able to get the tank back from the radiator shop. It actually came out real good. Did even require a the lining treatment so i save a few bucks there.
Got tank back in this morning with new sending unit float and filter. Also installed another inline filter before the fuel pump just in case of crud in the line. Also worked on the carb a little and installed new accelerator pump, power valve, and new base gaskets. When done she fired right up and idled even! No more fuel leaks either. Next goal, get leaky radiator fixed. Got a feeling it may be beyond repairMark
T-18 4 speed
Dana 44's
31x10.50x15
Originally posted by AuburnmarkWhile waiting on the fuel tank to get cleaned I did pull the distributor and recheck gears for oiling as Mikel suggested. Didn't see any unusual wear. I tried turning the pump to check for oil flow but really couldn't see much at that angle. Maybe if I pulled the fuel pump off I could get a better view ??? I will keep my eye on it. I would hate to ruin a virgin 360 with 60k on it over a stupid fried distributor gear!1969 M715 6x6
Originally posted by MikelGreat news. An easy check is to pull the distributor cap every once in a while and see how much angular play the rotor has. When my gears got chewed up, I ended up with A LOT of play
Anyway.... just as I suspected the radiator guy says mine has to many pin holes to fix. Of course he just happens to have the exact one (brand new) that has been sitting on his shelf for a while he would be more than happy to sell me. humm? $295.00 for a Modine brand.. anyone know if their any good??
Can,t really afford right now anyway, maybe next month.
I was able to get a new muffler from Summit for only $25 plus shipping so at least the neighbors are happy! Gotta love Summit Racing.Mark
T-18 4 speed
Dana 44's
31x10.50x15
Your rad guys can't re-core your original? Be careful, I've had rad shops quote me more than a new rad to re-core mine before. Modine is a good brand, though. $300 is what most replacement 3 cores seem to go for now days. I can't find the old 4 cores anymore unfortunately...if you're not worried about originally and looking for cheap, eBay has some China made aluminum replacement rads for cheap. A lot of people here run them with success.
EDIT:
Here ya go...
AMC 401 - Pro-Flo 4 EFI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Originally posted by Heavy_Metal_Thunder_81Your rad guys can't re-core your original? Be careful, I've had rad shops quote me more than a new rad to re-core mine before. Modine is a good brand, though. $300 is what most replacement 3 cores seem to go for now days. I can't find the old 4 cores anymore unfortunately...if you're not worried about originally and looking for cheap, eBay has some China made aluminum replacement rads for cheap. A lot of people here run them with success.
EDIT:
Here ya go...
http://pages.ebay.com/motors/link/?n...655407&alt=web
Thanks much for the link! That looks pretty decent for the money. It would be nice to keep original but only if it make sense .. dollar wise. Not that important to me. Before I chuck this one into the recycle pile I think I will take to another shop for a second opinion. Thanks for the info.Mark
T-18 4 speed
Dana 44's
31x10.50x15
Other priorities have slowed progress but still hoping to be roadworthy soon.
Meantime I started removing the crusty old, ugly, faded, petrified, wood grain decals. Tried everything I know to peel off and save the paint under but no way.. not even close. Finally had to get out the can of stripper, scrapers, and lots of sand paper. Pretty much had to take it down to bare metal to get it off!
Primer the bare metal.. and regroup to contemplate a new paint job
Mark
T-18 4 speed
Dana 44's
31x10.50x15
Originally posted by azmtn04That is looking really nice. Complete the orange or go two tone?
Mark
T-18 4 speed
Dana 44's
31x10.50x15
